Old 03-21-2006, 11:51 AM   #1
killingtime's Avatar
Default Modding Dischargers
Anyone have an idea on how to modify a discharger that has a 0.0 cut-off to something more useful, like a .5 or .9 cut-off?
The dischargers I have are the Integy Zero 6S and Zero-Thirty.
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 03-21-2006, 12:18 PM   #2
loopedeloop's Avatar
Axxis-Racing have a conversion for the integy 0-30 which gives a .85v cutoff.
You can find their contact details here:
www.axxis-racing.com
loopedeloop is offline   Reply With Quote
Old 03-21-2006, 12:29 PM   #3
XrayFK's Avatar
If you so a search this has been posted on a few times. I know I have posted a few times with instructions on making simple yet effective equalizing tray.
XrayFK is offline   Reply With Quote
Old 03-21-2006, 12:36 PM   #4
I have an email into Axxis inquiring about the kit. I would still like to know how this alternate cut-off rate could be accomplished as I would rather do it myself. Besides, they atate that thier kit is for the Zero-Thirty, but doesn't mention anything else.
Mike Webb
Old 03-21-2006, 12:48 PM   #5
XrayFK's Avatar
I believe the Axxis conversion for the 0-30 uses transistors to achieve a 0.85v cutoff. Last I heard they were still trying to get them from China or Japan.
As for the 6s tray you have, since that just uses a resistor, you can put a diode in line with it to have a cutoff of about 0.6-0.7v. Just make sure the diode is forward biased and can handle up to 6A or whatever the max discharge current would be based off the resistor.
Old 03-21-2006, 12:57 PM   #6
Last I heard is Axxis now has the conversion in stock.
To do it yourself will require 18 x 10A diodes or 6 x 30A.
Old 03-21-2006, 01:03 PM   #7
RCMits's Avatar
Trader Rating: 25 (100%+)
(edit)
never mind.. i was thinking the INDI reactor.
RCMits is offline   Reply With Quote
Old 03-21-2006, 01:06 PM   #8
XrayFK's Avatar
All those diodes would cost about $7. Although I was describing the diode method to use on the 6S tray.
Old 03-21-2006, 01:17 PM   #9
I priced the diodes over here in NZ .......................$9.00 ea
x18 = I could buy 2 0-30's for that.
I'm sticking with the axxis conversion
Old 03-21-2006, 01:24 PM   #10
XrayFK's Avatar
$9? Is that USD? Trust me, electronic components like diodes are dirt cheap.
Old 03-21-2006, 01:29 PM   #11
No thats NZD supplied by Jaycar over here.
rip off artists. even more expensive at dick smiths.
And your right they should be cheap as chips
Old 03-21-2006, 01:35 PM   #12
Send a message via AIM to rcguy2477
Using a diode with the 0-30 will drastically decrease the discharge rate(A=v/r, 1.5A=1.2v/.8ohms). When approaching .6v, the amperage will decrease, but it will not cut off like it would using a transistor.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 03-21-2006, 04:45 PM   #13
Try this link, it may be useful for what you are trying to do.
Jason K.
http://www.schumacher.clara.net/equaliser.htm
jjkahler is offline   Reply With Quote
Old 03-21-2006, 06:56 PM   #14
BATT_MAN's Avatar
There are many types of diodes, and yes they can be as cheap as $0.01 or you can pay $150 for a high speed, high amp rate schottky diode...
I know because we use and purchase them on a regular basis.
The problem with a REGULAR SILICONE DIODE is that you are NOT guaranteed that the cutoff will be the same on all diodes (even the same type and model). The other thing is that the 030 pulls in excess of 25 amps down to 0.85 volts and 36 amps at 1.2 volts. Just to play it safe you need 40amp diodes... or transistors that can handle the current and power (35 watts).
The other issue is thermal stability. Being that the 030 use resistors it does get very hot inside... If the diodes or semiconductors are not maintained at the right temp you will not get true equalization due to thermal drift.
There is not much place to install heatsinks for the semiconductors in the 030...so the right semiconductors need to be selected to maintain the temperature, sustain the power, and keep the voltage steady for real equalization.
That is why we have had delays with the transistors and the production of the 030 kits, because our supplier has shipped several times parts with the WRONG tolerances.
However, that issue has been resolved and we are getting product on a regular basis. The last semiconductors I received DID PASS our TEST.
Ihave been asked if this kit can be used with other dischargers and the answer is YES. However, the PC board is designed to nicely fit in the 030 (or Duratrax) We made si that the connections are simple to make. If you can build a battery pack, you can install the 030 conversion kit.
BATT_MAN is offline   Reply With Quote
Old 03-21-2006, 07:54 PM   #15
Thanks for the help guys!
Mike Webb
need help modding motors newrcguy2008 Electric On-Road 2 05-07-2008 04:19 AM
DIY Engine modding TeeKuang Malaysian R/C Racers 17 06-23-2007 09:29 PM
Modding Engines Goomba_7 Electric Off-Road 14 12-13-2006 10:21 AM
Modding a Motor fordman500 Onroad Nitro Engine Zone 4 08-17-2005 11:25 PM
Engine Modding Brett.w Onroad Nitro Engine Zone 0 10-09-2004 08:20 PM
