Like Tree1099Likes
Exotek F1ultra
Old 11-15-2022, 07:29 PM
  #1276
Originally Posted by ColbyB View Post
Mike,
is part # 2097 a replacement for the old blue suspension clips that we glued on?
yes, those are a replacement, and they are the best ones yet
ER_Torfulson is offline
Old 11-15-2022, 08:05 PM
  #1277
Regional Moderator
disaster999's Avatar
Mike, Are there any plans on selling the tire stickers itself? Its pretty hard to keep the one that came with the tires clean and damage free unless you dont crash at all.
disaster999 is offline
Old 11-16-2022, 10:22 PM
  #1278
MikeR's Avatar
Trader Rating: 15 (100%+)
We tried selling tire stickers before and only sold dozens so not sure we want to again
MikeR is offline
Old 11-17-2022, 11:17 PM
  #1279
Regional Moderator
That sucks, but completely understand.
Old 11-18-2022, 10:01 AM
  #1280
ColbyB's Avatar
For anyone waiting - I noticed soft fronts were on the site yesterday.
ColbyB is offline
Old 11-18-2022, 03:12 PM
  #1281
body super!
rus101272 is offline
Old 11-20-2022, 07:31 PM
  #1282
Anyone using the exotek xray gear diff spurs?
If I want to change from 64 to 48, how is that done? What is the math?
ryan391 is offline
Old 11-20-2022, 08:07 PM
  #1283
corallyman's Avatar
Trader Rating: 101 (100%+)
If you have a 100 tooth spur gear in 64 pitch. Take half of the teeth count of the 100, which would be 50 teeth in 32 pitch. (32 pitch existed before 64 pitch and was the standard years ago if you didnít know.).
Add the 100 and the 50 together youíd have 150 teeth. Divide in half that equals 75 teeth.
in short a 100 (64p) a 75 (48p) and a 50 tooth (32p) are all the same size and equal to each other. Hard to explain. Is that what you were asking?
Steve
corallyman is offline
Old 11-21-2022, 06:40 AM
  #1284
JCarr's Avatar
I ordered mine through Amain, hopefully they will get some and ship before 12/3. Considering just ordering another set from Exotek though. lol
JCarr is offline
Old 11-21-2022, 07:54 AM
  #1285
ColbyB's Avatar
mike ships just as fast! Although Iím located basically in the middle of Exotek and Amain haha
ColbyB is offline
Old 11-21-2022, 07:56 AM
  #1286
JCarr's Avatar
Back when I ordered mine, Mike didn't have any, plus I had a credit at Amain. Mike is a great guy and has always taken care of anything I have needed.
JCarr is offline
Old 11-21-2022, 02:23 PM
  #1287
Can someone educate me on the front damper tubes as a tuning aid.
It seems like a soft ie stock front spring with the damper tubes would help as the traction changed on a carpet track. Many times as the race day goes on some areas start to gain traction faster than orthers. Seems like this would even out the front end. Those that have used the front dampers, how and why did you use them?
ryan391 is offline
Old 11-22-2022, 11:21 AM
  #1288
ColbyB's Avatar
I switched this car over to 48p after stripping the stock gears twice during a shake down at the local school yard for whatever reason. And yes, I know how to set gear mesh. Been running 64p on other cars/chassis.
The exotek gears for the xray diff work well enough. Not much to say about a spur gear that works. You can buy Kimbrough gears to run 48p with the ball diff if you want to. 1/8Ē balls.
as far as ratios, Iíve always used this
Final drive calculator
ColbyB is offline
Old 11-24-2022, 06:02 AM
  #1289
Anyone running full set of Exotek tires on black carpet yet? I looked through here and didn't find anyone comment on front tires yet. I was able to get a full set of reds. Wondering about gluing sidewalls in the front like we do with CRC tires. Any tips on if its necessary and how much to start with?
rtebbe is online now
Old 11-24-2022, 07:20 AM
  #1290
I purchased a set initially with when I got the car, about a month ago. My home track is a Gravity tire spec track. We have to run Gravity. Since Gravity was out of stock I tried these. As far as I can tell the red dot were far and away better than the new CRC or Gravity. I glued the front as high as the stickers go, I did not have any problem with rolling. I have to glue the CRC all the way up to the running surface to get that kind of performance. The rears did not seem to wear in quickly. It has taken 100s of laps to get rid of the seem.
If it were legal to run a tire of choice at my track I would def be using the Exotek.
JCarr and rtebbe like this.
ryan391 is offline
