Old 03-21-2006, 03:39 AM   #1
Default 19t C2 Motor
I ran 19t at the weekend at a warm up meeting for the summer, it was my first meeting with 19t after racing mod for 10 years +.
The speed was better than expected.......but i could only get 1.5 runs out of a set of brushes, i was using the team scream H1 brush and the F lines. is this common, this was even after skimming and re seating the brushes.
The comm and the +ve brush would go black so it has been arcing but it does not seem to be sticking anywhere.
Anyone else come across this before?
LEE UK is offline   Reply With Quote
Old 03-21-2006, 05:14 AM   #2
John Tag's Avatar
Trader Rating: 42 (100%+)
For a lot of outdoors 19T racing lots run the Trinity XXX brush they get 20+ great runs... Hope this helps..
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 03-21-2006, 05:25 AM   #3
But are these a high performance brush?
Would you use them for nationals etc?
i dont mind replacing brushed every run but i just wanted to know if what i was experiencing was common?
Old 03-21-2006, 05:30 AM   #4
John Tag's Avatar
Yes they are a great brush. I have ran and tuned a few motors that made National A mains with this brush in past. There real popular outdoors in Florida in the US for 19T racing. As far as power you will be more than happy. When most brushes tend to heat up and fade 4 minutes in these keep rolling strong..
Old 03-21-2006, 05:32 AM   #5
TRF415boy's Avatar
I don't know about H1s but I use 767s and they last more than that, went to bedworth recently andcould probably do more than 6 runs on a set of brushes.
TRF415boy is offline   Reply With Quote
Old 03-21-2006, 05:36 AM   #6
John Tag's Avatar
Sounds like you could have brush hoods out of line or geared totally wrong also. Check with others to see what gear there running to get a good starting gear.
Old 03-21-2006, 05:52 AM   #7
Yeah possibly, this was supposed to be a tuned motor and alignment should have been checked during this i just thought it was very odd, its not as if the car slowed gradually, but litterally just stopped it doesnt even look like the brush has blued through excesive heat but the face has just gone black
Old 03-21-2006, 09:21 AM   #8
ooliganRC's Avatar
Send a message via MSN to ooliganRC
sounds like a F line brush issue.
they are inconsistent you may of had a bad pair.
xxx's hmmm still not convinced on these and at about £8 a pair chaqnging them every run is silly.
try the motor with a trusty pair of 4499's or full face 767's, if it blacks up again, strip the motor and realign everything and do it again...
if still no luck take it back and moan like hell.
Corally RDX PHi, Novak Brushless, Futaba 3GR, KO Propo 2413, E-Power 4500, Full Throttle Motorsports.
"You aint going fast enough, if you aint Full Throttle"
Currently slow due to : Bad thumbs and no motors :P
ooliganRC is offline   Reply With Quote
Old 03-21-2006, 10:04 AM   #9
It did the same with the H1 pair of brushes too, this makes me think it more of a motor issue than brushes.
Are the F lines that inconsistent?
I have heard you can get a bad pair but are they this bad?
Old 03-21-2006, 10:55 AM   #10
Send a message via AIM to R/C Anonymous
I've been running the XXX brushes for awhile in my Reedy QM 19T (carpet foam sedan class) out of the brushes I have tried the XXX brushes last the longest. I usually skim the comm between runs because it burns up(sometimes) but the brushes have no burnt look to them. Then I reseat the brushes for a few minutes with no load and at low voltage. I also check the spring tension with a Fiddlestick to see if the tension of the springs didn't weaken with heat or with a shorter brush.
I have heard there has been a bad batch over a year ago but lately the F brushes I use in my Axiom Atlas blue-can have been doing well.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 03-21-2006, 11:12 AM   #11
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
We just got around 1000 pairs and have seen good results on the Dyno and also great feedback from Customers so our batch is good - and on sale right now as well
dgullickson is offline   Reply With Quote
Old 03-21-2006, 11:43 AM   #12
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
This really sounds like more of a gearing issue.
Are you geared comparable to other's on the same track?
James Cooper
SouthernFriedRacing
[email protected]
SOuthernFRIED is offline   Reply With Quote
Old 03-21-2006, 12:16 PM   #13
yes i was geared at 5.5 most people were around this, the speed was good and it wasnt getting hot which also throws me a bit.
FS: MTRONIKS GENESIS TRUCK B/L ESC, FEIGAO 380C-6L MOTOR & REEDY NEO-ONE 4 STAR MOTOR davidrrr R/C Items: For Sale/Trade 5 08-16-2008 03:32 PM
FS/FT NIB LRP 5.5T Brushless motor/ Castle CM-2080 motor Trade for Newer FUTABA S9451 ffpm46 R/C Items: For Sale/Trade 13 03-31-2008 02:17 PM
Modify your stock motor, mod motor, any motor! TRF-Powered Electric On-Road 10 03-15-2007 05:52 PM
Trinity Motor Checker “Monster Horsepower Machine” Motor Performance Monitor CRiXman R/C Items: For Sale/Trade 5 01-25-2007 03:36 PM
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 11:22 PM
