Like Tree684Likes
Gt12 USA Spec
Old 08-12-2023, 10:43 AM
  #601
Has anyone tried the red endbell gravity motor with rubber tires? From what Iíve understood that red motor is designed for 1cell lipo while the black usgt motor is designed with 2cell lipo use.
Kruss45 is offline
Old 08-12-2023, 11:27 AM
  #602
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
The oval spec one ?
RKeasler is offline
Old 08-12-2023, 12:11 PM
  #603
Billy Kelly's Avatar
ThunderDome in Morris, Illinois run the red endbell USGT motor. Iíve also run the standard USGT motor. Iím about even with both. At first thought there was a bigger difference.
Billy Kelly is offline
Old 08-12-2023, 01:46 PM
  #604
what kind of lap times are you getting with the red endbell?
Kruss45 is offline
Old 08-13-2023, 05:25 PM
  #605
Up front runs high 11s/low 12s for average. Towards the back itís 13-14s average.
Kruss45 likes this.
Old 08-14-2023, 04:38 AM
  #606
[QUOTE=Billy Kelly;16025918]Up front runs high 11s/low 12s for average. Towards the back itís 13-14s average.[/QUOTE
thatís interesting what size track are you running on and whatís your grip level?]
Kruss45 is offline
Old 08-14-2023, 04:54 AM
  #607
[QUOTE=Kruss45;16025983]
100x48. Grip level seems good. Iím just bad at the class so taking a break. Hereís the last race https://youtu.be/_V9TXfMO4xI
Kruss45 likes this.
Old 08-14-2023, 05:19 AM
  #608
R/C Tech Elite Member
mrreet2001's Avatar
GT12-RT
mrreet2001 is offline
Old 08-14-2023, 07:11 AM
  #609
Dan
Dan's Avatar
Trader Rating: 76 (100%+)
I got better lap times with the red endbell motor after back to back comparison, even played around with gearing but the red endbell motor had a slight edge. This is only a single data point though with my testing...
Kruss45 likes this.
Dan is offline
Old 08-14-2023, 07:57 AM
  #610
No ... the Red end bell is meant for the Oval racers on 1S, it has more timing per Oval drivers crying.
The black one on road uses is the normal for big event spec motor racing.
Both can be used on 1s or 2s .... neither are designed for a specific lipo size.
Robbob is offline
Old 08-21-2023, 06:47 AM
  #611
There was some talk about using the red endbell motor as the standard motor for the class but it was decided to stick with the black endbell motor as more people had it already. The more this class is standardized the better it will be. Thatís my opinion.
Kruss45 is offline
Old 08-23-2023, 06:57 AM
  #612
Team EAM
Trader Rating: 79 (100%+)
Actually if you ask Paul the black endbell motor was setup and designed around 2S and he never anticipated it would work in 1S as well as it does. But he does feel the red one may be better suited for 1s applications with more timing in it. We've spoke about it when we were looking at making the red motor the one in GT12 but ultimately decided to stick with the black one due to everyone already having them.
EA
EAMotorsports is offline
Old 08-23-2023, 08:36 AM
  #613
EA
Never knew that part .... corrected
Robbob is offline
Old 08-23-2023, 08:45 AM
  #614
Casey's Avatar
EA
we tested the exact same thing here at 180, found that the red end bell, was slighlty different , but not enough for a gearing change from current USGT motor
We are still running the experiemental motors from Motiv from 2016 they are 17.5 , spec timed and marked. we have 22 of them and use them as handouts.
we also stuck with foam tires ..
internally contemplating changes for this season..
Casey is offline
Old 08-23-2023, 09:47 AM
  #615
Why don't you guys tell everyone they have to use the same tire, the same gearing, the same chassis, the same body, the same setup, the same ESC, the same servo. Or, you can make it open motor and get back to the spirit of competition and racing.
BullFrog likes this.
LowDrag is offline
