Like Tree684Likes
Gt12 USA Spec
Old 08-08-2023, 07:15 AM
  #571
R/C Tech Elite Member
mrreet2001's Avatar
Originally Posted by Kruss45
it wasn’t from being over geared. Some people take the rotor out and literally bake it in the oven.
What did that accomplish?
mrreet2001 is offline
Old 08-08-2023, 07:23 AM
  #572
LonnyJ1950's Avatar
It would kill some of the strength of the magnet. By weakening the magnet, you should get more top end and less torque. The amount of the effect would depend on how hot the oven was and how long you let it bake. I wouldn't recommend it unless you are really good at motor tuning and knew exactly what you were doing.
LonnyJ1950 is offline
Old 08-08-2023, 08:08 AM
  #573
I was hoping thats not what you meant but knew it probably was lol.
Its an old trick but easy to detect in tech.
You can drop a rotor's strength pretty easily if you do it right.
Theres no putting it back though if you dont pay attention to the timer.
And it tightens up your gearing window in my opinion.
Robbob is offline
Old 08-08-2023, 09:36 AM
  #574
Not in 12GT anyway. We are running at or near 1:1 with out a fan.
I'm having a hard time visualizing this, You really mean something like a 60ish spur and 50ish pinion?
mstrfahrenheit is offline
Old 08-08-2023, 09:47 AM
  #575
58 spur 55-57 pinion with usgt motor depending on tire size on mine
simple likes this.
Kruss45 is offline
  #576
simple's Avatar
No. Literally - 55 spur - 55 pinion or higher.. As long as whatever differential or spool outfitted on the car can accommodate it, some competitors outfit the smallest spur they can find, and correspondingly largest pinion.
Depending on the track and other conditions - some would even run higher than 1:1.
simple is offline
Old 08-08-2023, 09:56 AM
  #577
wow. TIL.
Where do you find such small spurs?
Old 08-08-2023, 09:58 AM
  #578
simple's Avatar
wow. TIL.
https://teameamotorsports.com/collec...car-spur-gears
Kruss45 likes this.
simple is offline
  #579
These are the times that we’re getting with the usgt motors. I’m #2 on the list and thats my best time ever
Kruss45 is offline
Old 08-08-2023, 10:06 AM
  #580
mrreet2001's Avatar
Yep! This coupled with the awsomematix gear diff.
Old 08-08-2023, 10:13 AM
  #581
no one runs the gear diff on black carpet
Kruss45 is offline
Old 08-08-2023, 10:24 AM
  #582
mrreet2001's Avatar
DIdn't realize that the GT12USA Spec was only allowed to be run on black carpet.
or that all black carpet is exactly the same.
Old 08-08-2023, 10:27 AM
  #583
Most indoor tracks have black carpet now
Kruss45 is offline
Old 08-08-2023, 10:40 AM
  #584
mrreet2001's Avatar
If someone needs to or wants to run a diff ... what's your problem with it? This class is suppose to be great for beginners. Jebuz.
Old 08-08-2023, 11:17 AM
  #585
simple's Avatar
I do when using rubber tire. It works awesome.
However, in this forum, since the topic is centric to foam tires, I run a spool in that case.
simple is offline
