Like Tree684Likes
Gt12 USA Spec
Old 02-02-2022, 03:57 PM
  #466
BadSign's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Kruss45
Johnn27 what motor are you using for that gearing range?
Iím using a hobbywing 21.5 at about 39-40 degree timing.1s battery. Iím currently geared at 68-49 and I have absolutely nothing for the top guys. Theyíre turning 11.6 - 12.0 lap times and my hero lap is 12.2. I canít seem to string low laps together. Itís not much fun when theyíre pulling 11.6ís and I have to pull over for them. Feeling a little frustrated about this
This is the hard part- figuring out where you're getting beat- mid corners, accelerating, or top speed- and why. GT12 is low powered, so you really have to get the car through the corners with a minimum steering throw. If you can keep up in the infield, compare the straight speed. And vice versa.
but .6 sec is probably getting you in the infield. Your car is probably understeering, especially mid corner and exit.
Billy Kelly likes this.
BadSign is offline
Old 02-02-2022, 04:56 PM
  #467
cementsurfer86's Avatar
I agree, and to piggyback off what John is saying, the idea is to get the car aggressive on turn-in (less caster) with good rotation, all with minimum input from the transmitter. That keeps momentum up and lap times down. I've had a ball learning about pan cars properly with this class. The amount of tuning and driving skill is still all there, but in a more manageable package for the masses. I started with a mellow, drivable setup, than ramped up the aggression as I got more comfy with the car. It's been a ton of fun,
RedBMaster and two shoes like this.
cementsurfer86 is offline
Old 02-03-2022, 09:01 AM
  #468
DARKSIDE's Avatar
what rules are you guys using... I noticed it varies at times between tracks/clubs...
this is what we are using at Apex
two shoes and Kruss45 like this.
DARKSIDE is offline
Old 02-03-2022, 09:18 AM
  #469
For Florida since we race outdoors just change the tires to foams-spec wgt..
BullFrog is offline
Old 02-03-2022, 09:29 AM
  #470
Trader Rating: 16 (100%+)
Limiting ESC to 1S only seems unnecessary. Some people use 2S ESC's along with a voltage booster.
mrreet2001, TOM MAR and two shoes like this.
glennhl is offline
Old 02-03-2022, 09:53 AM
  #471
DARKSIDE's Avatar
hummmm... let me check on that...might be just a mistake
DARKSIDE is offline
Old 02-03-2022, 10:05 AM
  #472
By the way if any of you want to come down and get practice for the Nationals just check out the Valkaria posted race schedule. If you have a small airplane you can land next door and walk across the street.
BullFrog is offline
Old 02-03-2022, 10:11 AM
  #473
DARKSIDE's Avatar
"Any 1s capable ESC" should fix it. I'll get the update in
glennhl likes this.
DARKSIDE is offline
Old 02-03-2022, 12:24 PM
  #474
Up here in the PNW, we are doing a spec motor (Hobbywing Justock 17.5FT) and spec gearing (72/40), but other than that, same as above.
Old 02-03-2022, 01:44 PM
  #475
DARKSIDE's Avatar
Better?
DARKSIDE is offline
Old 02-03-2022, 05:18 PM
  #476
TheBeave's Avatar
How are the consistencies with the spec motors and gearing? Have you had any motors where they're just faster/hotter out of the pack compared to others?
TheBeave is offline
Old 02-03-2022, 05:43 PM
  #477
busman's Avatar
Soooo! I should swap to a 17.5 for next Wednesday instead of the 21.5 I ran a few weeks ago?
busman is offline
Old 02-03-2022, 08:49 PM
  #478
two shoes's Avatar
Trader Rating: 21 (100%+)
Agreed!
two shoes is offline
Old 02-04-2022, 09:07 AM
  #479
oldrcr's Avatar
Trader Rating: 46 (100%+)
We have not set our rules yet. If you want to run what is starting to become what several are running now, the HW stock Spec 17.5 which has fixed timing of 45* I think, if you want to use a different 17.5 with 45* and then run the 40/72 gearing, odds are you will be close enough. We are having fun so far, still sorting it out a bit, so just race what you have ready.
-a
oldrcr is offline
Old 02-04-2022, 09:22 AM
  #480
oldrcr's Avatar
So far the HW seems to be consistent. We have a couple more that will run that same motor the next race, so we will have more data. The few that have run the HW fixed timing 17.5 and 40/72 gearing have all been the same speed, no one faster in a straight line. The motors all come off barely warm.
-a
oldrcr is offline
