Like Tree684Likes
Gt12 USA Spec
Old 01-01-2022, 02:55 PM
  #361
We are running the gloriously underpowered HW 17.5 g2.1.....solves all the weight problems if you balance the car at all. 177g of bliss.
Carnage9270 is offline
Old 01-02-2022, 09:31 AM
  #362
Trader Rating: 16 (100%+)
I decided to try out the Xray Gear Diff yesterday on my GT12 car. I was running a spool but I definitely liked the gear diff better. Car turned better and drove off the corners very well. I'm sticking with the gear diff.
glennhl is offline
Old 01-02-2022, 06:25 PM
  #363
Trader Rating: 28 (100%+)
Thinking about building one.
has anyone had the A12 and the x12?
curious to which you prefer and why.
thNks all
mjordan44847 is offline
Old 01-03-2022, 05:41 AM
  #364
I agree. Much more consistent with the gear diff and same or better lap times.
old_dude is offline
Old 01-03-2022, 08:42 AM
  #365
hollywood3705's Avatar
they both are wonderful but drive
completely different, I use a lot of wheel throw compared to
some And the a12 seems to have a tad push on entry with great mid to exit steering. I can now add entry steering as I need or desire. The x12 steers very heavily going in and tends to push mid to exit. Exit steering can be added there as well. So for me it came down to simply the way I drive and want a car to drive, so I stuck with the a12
thNks all
mjordan44847 and gwc like this.
hollywood3705 is offline
Old 01-03-2022, 08:46 AM
  #366
YBSLOW's Avatar
Originally Posted by oldrcr
Hi,
I was admiring the pic of your nice clean set-up, and noticed the red and black wires on the capacitor for the esc look very close to touching each other. I had that happen once, touch together, and so is only reason I took notice. Maybe the angle of the picture makes it look closer than they are.
-a
Is that a custom battery mount or is that forsale somewhere? Looks great I need two of them.
YBSLOW is offline
Old 01-03-2022, 09:24 AM
  #367
R/C Tech Elite Member
mrreet2001's Avatar
What cst / brand silicon oil did you use?
mrreet2001 is offline
Old 01-03-2022, 03:06 PM
  #368
OK, my only complaint is a lack of small enough ring gears. I bought the smallest I could find, 76 teeth and the largest pinion that will fit on the X12 is a 54 (130 total teeth), so I'm stuck at a 96 roll out with a 43mm rear tire. Does anyone know if anyone makes a 72 tooth ring gear for the Xray Gear Diff? Thanks, Glenn
glennhl is offline
Old 01-03-2022, 04:53 PM
  #369
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
they make smaller spur for Xray gear diff
but only sell them over sea..
X-Ray X1, X10 & X12 Acetal Diff Spur Gear (rwracing.co.uk)
Or you can get the 48P at Exotek Racing
sorry
Juniorabca and glennhl like this.
OVA is offline
Old 01-03-2022, 05:56 PM
  #370
Well if you are talented enough you can take someones gear and cut it to work. It has been done before!
glennhl likes this.
BullFrog is offline
Old 01-03-2022, 08:01 PM
  #371
jetnjme's Avatar
Trader Rating: 19 (100%+)
fenix racing makes 70 and 72
get a hold of fenix racing USA and see if he has them or if he can order them in.
Fenix spur gear for xray gear diff
jetnjme is offline
Old 01-03-2022, 08:10 PM
  #372
jetnjme's Avatar
Fenix racing usa
jetnjme is offline
Old 01-03-2022, 08:16 PM
  #373
jetnjme's Avatar
If RW makes them get a hold of
Team EAM
and ask if they can order some from overseas.
worth a shot
jetnjme is offline
Old 01-03-2022, 08:46 PM
  #374
OVA
OVA's Avatar
Xray differential spur gear - FenixRacingShop
OVA is offline
Old 01-03-2022, 09:11 PM
  #375
Huge thanks for all the links. Thank you.
glennhl is offline
