Like Tree684Likes
Gt12 USA Spec
Old 12-30-2021, 10:48 AM
  #346
Trader Rating: 27 (100%+)
S/O to people that do one color paint jobs cuz I'm lazy and not masking shit opposed to 'saving weight'
LonnyJ1950 likes this.
phatboislim is offline
Old 12-30-2021, 11:27 AM
  #347
I'm also in the one color camp. A haphazardly applied two-colored fade, if I'm feeling frisky.
bentouttashape is offline
Old 12-30-2021, 12:47 PM
  #348
Trader Rating: 17 (100%+)
Originally Posted by robk
We're going to have some races, so this is not just a theoretical exercise.
Perfect rule set!
Kave is offline
Old 12-30-2021, 02:08 PM
  #349
Can we PLEASE reduce the minimum weight? IMO its Fín stupid to be adding a 35+ gram steel ballast bar just to get up to the 730 minimum weight rule. And thatís with a GT body. Even more useless ballast is necessary when running a regular weight black-art Toyota. I do nothing special to save weight on my cars and it seems so stupid to be putting tungsten plates under the battery or big heavy steel bars in front of it.
phatboislim likes this.
vafactor is offline
Old 12-30-2021, 03:15 PM
  #350
Are the aluminum chassis cars heavier?
Old 12-30-2021, 03:21 PM
  #351
Yes, so are other common things like a tekin speedo, diff versus a spool, large milliamp packs, ECT. Wires could be 5 grams without lengths cut down, or going to 16ga. The rubber tires for the class weigh more than foams as well.
Racermac73 is offline
Old 12-30-2021, 03:40 PM
  #352
Trader Rating: 45 (100%+)
Default VTA
I also do one color only. If I feel adventurous I might use some pin stripe tape on the car too. That does not happen very often. Lol. Happy New Year to ALL of you.
jammin684 is offline
Old 12-30-2021, 03:42 PM
  #353
Then an $8 weight doesn't sound like a big deal.
Old 12-30-2021, 05:06 PM
  #354
I concur.... even in my mod car with a heavy ass speedo and 8k pack in adding a little weight.
Old 12-30-2021, 06:33 PM
  #355
gubbs3's Avatar
My GT12 at champs was 760 with zero weight added. All carbon car. No alloy screws, big speedo, heavy servo, big wire, 8200 pack, thick paint. Just because you "can" get a car super light doesn't mean it is healthy for the class.
Heavy cars drive better.
mjordan44847 likes this.
gubbs3 is offline
Old 12-30-2021, 08:10 PM
  #356
Dan
Dan's Avatar
Trader Rating: 76 (100%+)
Big difference between foam tires and spool versus SJT rubber tires and ball diff for weight. Sometimes the grip is not high enough to warrant a spool with the rubber tires, hence the issues trying to get close to the minimum weight once you factor in a ball diff or if your car has an aluminum chassis.
Dan is offline
Old 12-31-2021, 10:52 AM
  #357
MikeO's Avatar
small esc, small RX, small servo, small cap, spool, carbon chassis, foam tires. Im not surprised youíre adding weight. Iíd be happy youíre adding weight, a lot of us arenít.
MikeO is offline
Old 12-31-2021, 12:50 PM
  #358
bmwjoon's Avatar
Making GT12 lighter than LMP is not what anybody should be thinking about nor does it make sense. If anything with heavier bodies the class weights should be higher.
BullFrog, simple and ckrell like this.
bmwjoon is offline
Old 01-01-2022, 02:33 PM
  #359
oldrcr's Avatar
Trader Rating: 46 (100%+)
Hi,
I was admiring the pic of your nice clean set-up, and noticed the red and black wires on the capacitor for the esc look very close to touching each other. I had that happen once, touch together, and so is only reason I took notice. Maybe the angle of the picture makes it look closer than they are.
-a
oldrcr is offline
Old 01-01-2022, 02:47 PM
  #360
Originally Posted by oldrcr
Hi,
-a
Looks like they are close to touching together and the red looks like it's close to touching the can as well
Carnage9270 is offline
