Old 03-20-2006, 04:21 PM   #1
Default Sorex Rubber Tires
Summer is approaching, I will be running my Tamiya cars on a clean one year old asphalt track. Are Sorex tires good for that condition? Also, do they last long?
I am new to outdoor electric racing, so I need to know if these are the right tires.
trf_racer is offline   Reply With Quote
Old 03-20-2006, 05:19 PM   #2
outdoor asphalt i run 36 with C-medium inserts.
can also try 32 or 40's
buy those 3 and you will be set.
XingXing is offline   Reply With Quote
Old 03-20-2006, 05:26 PM   #3
Are they durable? Usually how long do a set last?
Old 03-20-2006, 05:33 PM   #4
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
How well a tire works and how long they last varies from track to track. I know at SoCal, we run Sorex 36R's mainly. A tire that you would normally think of as a high temp tire. We run them indoors in both hot and cold weather. They just happen to work there. Also, they'll last a good 5-6 runs without dropping off at all. In fact, you need to scrub them in once before you race them. And beyond 6 runs, you can get a good 5 more out of them at least as practice tires. On the other hand, I know the boys down in Florida have told me that on the tracks they have there, Sorex tires are a one run tire, period.
Jon Kerr is offline   Reply With Quote
Old 03-20-2006, 05:44 PM   #5
i run them till they show the inner lining. then use them as practice tires.
that will last over 4 race meets in stock. and prob 3 race meets in mod.
Old 03-20-2006, 09:59 PM   #6
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Yep it depends on the track and class you are running. Mod guys here can get 2 runs on a track but stock guys can get 6 months worth
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 03-20-2006, 11:26 PM   #7
Depends on what you call runs? you can sometimes get a whole heap of runs out of the tire before you see canvas, but generally it is only the first 2-3 runs where the tire actually has any decent grip. Go check your lap times most instances the car will be noticeably slower on subsequent runs.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 03-20-2006, 11:52 PM   #8
Drewdc90's Avatar
It depends on how abrasive the track is as well.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 03-21-2006, 08:51 AM   #9
zipp's Avatar
will a set of 40Rs last significantly longer then a set of 36Rs?
zipp is offline   Reply With Quote
Old 03-21-2006, 01:30 PM   #10
Jon Kerr's Avatar
In theory, yes. The only way to know for sure on your track is to try it.
Sorex 28 rubber tires nitrobeast R/C Items: For Sale/Trade 15 08-24-2008 07:07 PM
f/s rubber tires (takeoff, sorex...) seaball R/C Items: For Sale/Trade 11 07-21-2008 04:19 PM
Sorex Tires Lot of rubber little$$$$ RandyB R/C Items: For Sale/Trade 6 04-04-2004 02:06 PM
rubber tires for sale: CS27s, Sorex Euge R/C Items: For Sale/Trade 6 02-24-2004 01:09 PM
New and used rubber tires- Sorex and Pits BigDogRacing R/C Items: For Sale/Trade 13 09-27-2003 10:44 AM
