hb tcx parts
Old 05-17-2020, 12:13 AM
Default hb tcx parts
just purchase a hb tcx kit used, the kit is missing the front and back pivot blocks. Does any one know were I could find them? Or any aftermarket ones that would fit.
thanks in advance for any help.
Dmgp1 is offline
Old 05-17-2020, 12:31 AM
JoeyE's Avatar
Trader Rating: 45 (100%+)
https://www.ebay.com/itm/Hot-Bodies-...gAAOSwWiBY~ghc
JoeyE is offline
Old 05-17-2020, 01:04 AM
Thank you purchased it right away, 3 more to go.
Dmgp1 is offline
Old 05-20-2020, 11:17 AM
SuperFastSnail's Avatar
Trader Rating: 82 (100%+)
You can also try the exotek ones, I think they are pretty universal for the earlier time period cars such as the HB, Team Associated, Tamiya cars.
SuperFastSnail is offline
Old 05-21-2020, 12:22 PM
Thanks, so far have found 3 pivot blocks, just looking for pivot block 68755. I found different ones that have different degrees, they are front rear, how much does the degree effect the car? I'm probably just going to purchase the 1 degree pivot block
Dmgp1 is offline
Old 05-21-2020, 05:46 PM
Airwave's Avatar
Are we talking about that?
Originally the TCX use 2.5 as FF, +1 as FR , 0 as RF and 3 as RR.
It was clearly one of the important setup point of the car. It will change the behavior of the car...
Airwave is offline
Old 05-22-2020, 10:02 PM
I think those go on the outside of the bulkhead not sure the one I'm looking for goes on the front behind the bulkhead if that makes sense. I can't post pics yet, so can't add an example
Dmgp1 is offline
Old 05-24-2020, 03:28 PM
Airwave's Avatar
that's what I meant with the notation I used, they are quite common:
  • FF is the part fixed behind the bumper
  • FR is the part near the steering
  • RF is the part behind the motor
  • RR is the part at the rear extremity of the car
Your RF is probably more like that
The +0.5 indicates that you must substract 0.5 to the FF block. It also exist in 0, +1 and -1.
You can also find split blocks like these:
Airwave is offline
Old 05-25-2020, 02:41 AM
Yes, 68755 look similar to your image. I was just going by the manual and trying to attain the parts it calls out for. I wasn't aware I could use the split blocks, are they preferred?
am I able to use any block as long as it states its an FR.
thank you for the info, I'm a noob to these touring cars
Dmgp1 is offline
Old 05-26-2020, 06:03 PM
Airwave's Avatar
You can, this is a setup option. Split blocks will give you a little more front flex, so it can help the car enters the corners. Mainly depends on grip...
Airwave is offline
Old 05-27-2020, 11:46 AM
Do you happen to know if the tcxx pivot blocks will work? I found (tcxx)68476, from the images it doesn't seem to be the same as the (tcx)68755, it does state its F/R.
I did look through the old tcxx thread and I believe one post stated they were interchangeable. Your advice would be greatly appreciated
thank you
Dmgp1 is offline
Old 05-27-2020, 03:17 PM
Airwave's Avatar
quite hard to remember. I know that Cyclone TC has only 2 holes for FR block. I think TCX has four. If it is the case, they are the same parts (as most of the rest of the car by the way)
Airwave is offline
