Old 06-23-2006, 09:27 AM   #76
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Originally Posted by Mutabarucka
Ray, i ran my motor 2-3 tooth up from my C2 and it was faster than the C2, i tried doing what you did but it was not as fast i was suprise you went down that much and was still fast.
your c2 was geared wrong.
look at the stack of each motor. the differences between the two indicate that the kd is going to have more rpm. and it does. relative to a correctly geared motor, you need to gear down for a higher rpm version.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 06-23-2006, 09:36 AM   #77
seaball's Avatar
also, i have found that even good 19T motors burn up when geared for the best lap times for 5 minutes. i rarely gear based on motor temp. if i gear for lap times, they come off hot, and the brushes look like a rainbow. even in this condition, my last laps are only .2 slower than the first few. if the spread is less than that, you're not taking advantage of the voltage curve up front!
i'm not a motor tuner by any stretch, but i log alot of laps in. and this is my finding with both the c2 and kd. how bad they burn up usually depends on what brush is in there.
Old 06-23-2006, 10:53 AM   #78
dawgmeat's Avatar
Has anybody tried the XXX brushes with the dragon and would using a modified ESC profile help with the burnt brushes or will that make the motor soft?
dawgmeat is offline   Reply With Quote
Old 06-23-2006, 12:44 PM   #79
seaball's Avatar
i'm sorry for not clarifying. as you surmised, i was referring to the standard copper compound brushes. the silver ones, don't discolor. i have not had the silver brushes build up well with stock motors, though. we have just recently been running them in 19t, but it could just be an average, or below average lot of brushes.
Old 06-23-2006, 01:41 PM   #80
I know that with a higher rpm motor you would gear down as with a mod motor but i did gear down first 1 tooth and it was much slower than my C2 and i went down 2 tooth and it was worst so i went up 1 tooth and it was much better so i went up 2 tooth and that hit the sweet spot i was blazin fast and for my C2 I have it gear right because i am in the A main with the top racers with that gearing, it might be one of those fluke motor i have but it work for me.
Mutabarucka is offline   Reply With Quote
Old 06-23-2006, 01:48 PM   #81
seaball's Avatar
fair enough. but it should surprise you more that you are two teeth up, not that rayhuang is a few teeth under! one of your motors is an anomaly.
Old 06-23-2006, 06:34 PM   #82
Big Rigg's Avatar
I can see that... I have 3 dragons and one of them has the magnets shifted inside the can, you can acctually see the edge of one side thru the vent hole... unfortunately it is shifted the wrong way and is wayyyyyy slow at any gearing, (I ended up gearing it similar to a Reedy) but it gets about 10 minutes of runtime for practice... for the other 2 I gear 2 teeth lower than a C2 and they are alright, but with 4499s they cook at the 3-4 minute mark. I'm gonna try the XXX brushes next.
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 06-23-2006, 08:40 PM   #83
tandman's Avatar
Send a message via Yahoo to tandman
I used to gear my C2's 3-4 teeth up from what I ran for stock(monster 48 pitch), now with the Komodo I run the same gearing as stock and my Cyclone is .3-.4 quicker per lap than my best C2 on an outdoor paved track....temp comes off around 150-160f and I can get 2-3 runs with F-brushes just skimming the com between runs. Gearing is 27-28/81 spur fdr is 7.31-7.05. 120' straight with a fairly flowing layout.
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
Old 06-23-2006, 08:58 PM   #84
AdrianM's Avatar
The magnet shift is a big deal. I have two perfectly centered Komodo that are fast. My very lucky buddy has advanced magents in his and its a monster in 1/12th.
Adrian Martinez
Old 06-23-2006, 09:05 PM   #85
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I really like the XXX's in the komodo. I tend to spring my motors on the heavy side, but I think with the XXX's it is a good match.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 06-23-2006, 09:31 PM   #86
Trader Rating: 22 (100%+)
Send a message via AIM to AChupp2
Anyone have a gearing suggestion for a T4?
Fantom Racing Team Manager
AChupp2 is offline   Reply With Quote
Old 06-23-2006, 10:00 PM   #87
protc3's Avatar
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 06-23-2006, 10:02 PM   #88
AdrianM's Avatar
Originally Posted by protc3
Adrian Martinez
Old 06-23-2006, 10:06 PM   #89
protc3's Avatar
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 06-23-2006, 10:15 PM   #90
AdrianM's Avatar
To my left there is a motor breaking in that will make our next race result in some for you...(insert evil laugh)!
Adrian Martinez
Komodo Dragon II 19t wolfden R/C Items: For Sale/Trade 0 01-19-2008 09:02 PM
Trinity 10.5 vs Komodo Dragon 19T nhra6849 Electric On-Road 5 01-16-2008 10:19 AM
What FDR for a Komodo Dragon 19T? martman_oc Electric On-Road 3 12-07-2007 03:56 PM
WTB. Komodo Dragon 19t and XRS or Rooster ESC OG RC 10T R/C Items: Wanted to Buy 6 12-04-2007 09:07 PM
Komodo Dragon Johnny Wishbone Electric On-Road 13 06-06-2006 12:54 AM
