Old 05-10-2006, 12:16 PM   #46
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
Gear it like you would a 12x1 Deznutz, cause that's basically what it is. If you were to unwind an arm and measure the wire, that's just about how much is on there. With the stack being shortened 4mm and the webbing of the poles 2mm thinner, the thing is ballistic for a 19T.
RcCzarOfOld is offline   Reply With Quote
Old 05-10-2006, 02:25 PM   #47
Send a message via AIM to Deznuts05
so I guess 100/36 with 57mm foams was bad then huh?
what gets me was that I was getting walked on by my friend who has the same motor I just have more RPM then he does... any ideas?
Deznuts05 is offline   Reply With Quote
Old 05-10-2006, 05:20 PM   #48
new92's Avatar
Seriously gearing it like that? I was thinking about picking one up tomorrow for this weekend but its kinda hard to experiment before heats due to limited practice and no timinig during practice. So like the co27 that starts 4 or 5 teeth higher than the monster....start this one .......how many teeth from a C2 you guys think?
Our layout right now has 2 chicanes, 2 180s, and a HUGE sweeper, almost like one long straight since it uses the half the backstretch, 2 corners and half the front stretch of an oval with a 315' run line.
new92 is offline   Reply With Quote
Old 05-10-2006, 05:23 PM   #49
new92's Avatar
You can see the layout here, scroll down to the "facelift" pictures...
HobbyWorld
Gearing I was running 6.09 with a C2 and it was smoking coming off but I wasnt the fastest top end, but i didnt have any bigger pinions at the time.
The picture at the top of the first page is not the layout now. Under facelift the back stretch has the gate from the onroad to the oval closed, when we run that short chute is opened up onto the back straight
Old 05-14-2006, 08:36 PM   #50
protc3's Avatar
i ran one this weekend in my 1/12th scale.my god is this thing fast.no one had motor for me this weekend.i have to say it is the fastest 19 turn i ever had.for 1/12th outdoor it really liked the xxx brush with a verticle slot in the center on the brushes and a green spring + and -.absolute missile.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 05-14-2006, 10:01 PM   #51
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Thank's for getting my pal Eric Hill hooked on 12th, I've been slowly trying but I guess you sealed it. What gearing ratio with this motor worked for you?
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 05-14-2006, 10:24 PM   #52
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
hey Jason I just finished my Komodo
at 7 volts
rpm torq watt ef amps
26219 8.0 166 71 31.2
25430 9.0 180 71 34.0
24560 10.2 195 71 37.1
23883 11.1 206 70 40.0
23165 12.1 217 68 43.4
22396 13.1 225 66 46.9
full face brush purple+ red -
Im going to try it this weekend and Ill try it on my 12th scale if I have it ready by then.
Old 05-14-2006, 10:30 PM   #53
SWTour's Avatar
C2
RPM Torque Watt EF Amps
22169 11.0 182 77 33.3
21549 12.0 194 76 35.9
21018 13.0 209 75 38.7
CP Money 19 Turn
21670 11.0 178 78 32.4
20970 12.0 187 75 35.1
20459 13.0 199 74 38.1
KD-19 Turn
28429 8.0 170 75 32.3
27653 9.0 185 74 35.3
26637 10.0 200 75 37.9
I deleted the high and/or low numbers and just grouped the 3 motors by relative AMP draw. Looking at this data, I would conclude that the KD-19 has less TORQUE, similar Watts & Efficiency. The C2 still seems to create MORE Power/Watts in a equal AMP draw test, but the KD-19 does have a TON more RPM.
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 05-15-2006, 04:50 PM   #54
protc3's Avatar
roll out was 52.59
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-15-2006, 06:27 PM   #55
Glowster21's Avatar
Trader Rating: 116 (100%+)
Ran a Komodo this weekend and all I can say is that I am a Trinity believer again!!! This motor was INSANE!!! Rolled it out in an RDX on the carpet with foams at 29.5 mm and it was very fast. Came off the track at 120 degrees...I didn't get enough time to really play with the gearing but it ran for 8 minutes on a 3800 unmatched practice pack and was noticabley faster than my Checkpoint Money motor. When I finally hit the gearing right the motor will be EXTREMELY FAST. This is going to be the motor to run for the carpet season. Great job to the guys and girls at Trinity for making the Komodo the motor that it is.
Glowster21 is offline   Reply With Quote
Old 05-16-2006, 11:46 AM   #56
sukh's Avatar
I tried the komado in my t2 last week, this motor is fast but it came of smoking hot, i geared it the same as my c2 around 30 mm roll out, i think you have to gear the komado a few teath lower than the c2, what do you guys think?
sukh is offline   Reply With Quote
Old 05-16-2006, 11:50 AM   #57
John Tag's Avatar
Trader Rating: 42 (100%+)
Yes..Most are gearing the KD 2 teeth less than C2 for starting point..
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 05-16-2006, 11:51 AM   #58
rayhuang's Avatar
yup Thats what everyone is saying on here. About two teeth. if yu read the dyno sheets posted by EA on page one-it has more rpm then the other 19t's. The dyno sheets are in torque steps so you can read what a C2's rpm is and what the KD's is and adjust accordingly.
I rolled out my C2 last race at 1.195" (30.3mm) and it ate the brushes every run. Car was still fast at end of run-but the comm was red and + brush was rainbowed. If the KD is faster at two less teeth and has stock motor brush wear-BRING IT ON!!!
Old 05-16-2006, 11:51 AM   #59
rayhuang's Avatar
Awesome-what I said only in60 less words!! HAHAHA!! I suck.
Old 05-16-2006, 12:01 PM   #60
Tim Stamper's Avatar
At CEFX, I usually rollout a C2 at 1.18", a CP at 1.20", a Integy at 1.21", Blue atlas at 1.23" and the KD at 1.0"-1.02"
Less torque and more RPM means gear it lower.
It won't seem like it's overgeared at 1.10-1.15, but it never hits top rpm and keeps pulling through the sweeper. It still feels as it has punch, and then you gear down and hear the whine down the straight and it sounds like a 10-12 turn.
Mine hits 165-180 degrees on a semi-technical 80x40 carpet track.
Good luck,
Tim
This space for rent
Tim Stamper is offline   Reply With Quote
Komodo Dragon II 19t wolfden R/C Items: For Sale/Trade 0 01-19-2008 09:02 PM
Trinity 10.5 vs Komodo Dragon 19T nhra6849 Electric On-Road 5 01-16-2008 10:19 AM
What FDR for a Komodo Dragon 19T? martman_oc Electric On-Road 3 12-07-2007 03:56 PM
WTB. Komodo Dragon 19t and XRS or Rooster ESC OG RC 10T R/C Items: Wanted to Buy 6 12-04-2007 09:07 PM
Komodo Dragon Johnny Wishbone Electric On-Road 13 06-06-2006 12:54 AM
