Team associated tc 6.1 help >
Old 04-30-2020, 09:12 PM
Default Team associated tc 6.1 help
Anyone know what pitch pinion I need for this car thanks
chuckie86 is offline
Old 04-30-2020, 09:42 PM
Trader Rating: 39 (100%+)
I believe the AE off road buggies and SCt's run 48 pitch spur/pinion gears. At least that's all I've ever run in my AE vehicles.
jammin684 is offline
Old 04-30-2020, 10:40 PM
gigaplex's Avatar
The TC6.1 is a touring car and this is the on road forum.
Use either 48p or 64p, just make sure the spur matches.
gigaplex is offline
Old 04-30-2020, 11:19 PM
wtcc's Avatar
The kit comes with a 48dp spur.
wtcc is offline
Old 05-01-2020, 12:09 AM
rc_square24's Avatar
If you're unsure what you have on your car, either post a photo of it , or you can count the number of teeth one inch of gear circumference. It should be either 64 or 48. Sometimes its marked on the gear itself.
rc_square24 is offline
Old 05-01-2020, 08:05 AM
Trader Rating: 14 (100%+)
The way to find the gear pitch is to count all the teeth, then measure the gear diameter and divide the number of teeth by the gear diameter. This isn't exact because you should actually divide by the diametral pitch diameter which is slightly less than the overall diameter, but it will get you close enough to figure out if the pitch is 64 or 48.
glennhl is offline
