1/10 pan car
Old 04-20-2020, 07:48 PM
Default 1/10 pan car
Looking for a input on 1/10 pan car. I have been told
this one over the past 2years but just been doing other things and now just want to see what you guys have seen on the pan car scene since 2 years.
https://www.amainhobbies.com/crc-gen...ln1801/p268819
lighttravler is offline
Old 04-20-2020, 07:50 PM
Oh will be driven on asphalt
Old 04-20-2020, 09:06 PM
JeffofSpace's Avatar
Get the newer gen x 10 RT. Great car.
JeffofSpace is offline
Old 04-21-2020, 02:36 PM
Can you explain why I was giving the first choice and the slider edition never stays in stock but the One yju suggest always in stock?
Old 04-21-2020, 05:28 PM
The Gen-X SE you were suggested is an older model that was designed around foam tires and the WGT class rules. The foam tires caused a lot of racers to leave the class and it was rejuvenated to a point as WGT-R using rubber tires. The Gen-X RT was designed around this change and is the current 10 scale car CRC is selling that is why is in stock. Not sure if you are using this as a WGT-R or some other class but these are both 200mm wide racers. The two cars share many of the same parts.
sweems is offline
Old 04-22-2020, 06:20 AM
Ok thanks I was just wondering most always recommended that the SE. it want be used for any class but thanks for the explanation
Old 04-22-2020, 10:30 AM
The SE can easily be converted to use rubber tires all you need are the set of 3, 4 and 5 mm spacers CRC sells or other spacers to get under the lower arms allowing ride height for rubber tires. Conversely the RT runs just fine on WGT foam tires, I've used them on new tracks until the traction comes up and by changing the spacers you can account for the differing ride heights with the foams.
sweems is offline
Old 04-22-2020, 08:20 PM
Ok cool sounds like the RT might be choice over the se.
