New Tamiya Chassis TC-01 >
Like Tree778Likes
    Hide Wikipost
Old 12-05-2020, 09:50 PM   -   Wikipost
R/C Tech ForumsThread Wiki: New Tamiya Chassis TC-01
Last edit by: RCBuddha
INSTRUCTION MANUALS:
Vehicle instruction manual: https://cdn.simba-dickie-group.de/do...2-car-tc01.pdf
Formula E body instruction manual: https://cdn.simba-dickie-group.de/do...e-gen2-car.pdf
HOPUPS:
DRIVE TRAIN:
Universal Prop shaft (TC01): #54975
Double Cardon Prop Shaft (TC01): #54961
Aluminum spur gear holder: #54903
Universal shafts: #54515
Clamp hex hub: #53570 or #53823
Double cardan shaft: #42360
Double cardan joints (TRF): #42216 (set) & #42239 (42mm shaft)
Different Aluminum Drive Cup: #54543
Steel Bevel Differential Gears: #54540
Gear Differential Steel Cross Shaft: #54533
BEARINGS (in MM):
3x6x2.5: x2
9x5x3: x1
9x5 (flanged): x1
5x8x2.5: x12
5x10x4: x10
5x10x3: x2
10x15x4: x4
SCREWS:
3x5mm Titanium Hex Head Screws x4
3x6mm Titanium Hex Head Screws x6
3x8mm Titanium Hex Head Screws x18
3x10mm Titanium Hex Head Screws x13
3x12mm Titanium Hex Head Screws x12
3x6mm Titanium Hex Head Countersunk Screws x5
3x8mm Titanium Hex Head Countersunk Screws x10
3x10mm Titanium Hex Head Countersunk Screws x8
SUSPENSION:
Suspension arm mounts (rear skid angle): #54787
Supension arm mounts: #54760
Stabilizers: #54956
Aluminum rocker arms: #54955
TRF big bore shocks: #42354
TRF works shocks: #84317
TRF Special shocks: #42102
Carbon rear crossmember: #54783
Carbon front crossmember: #54782
Low friction suspension balls: #54747
Titanium Coated suspension shaft: #53581
Flourine supension balls: #53709
Titanium Coated Shock Shaft: #54043
Aluminum shock extenders: #54960
WTCC's adjustable suspension Conversion:
Parts needed:
3x23mm turnbuckles (x8)
Yokomo #BM-206
Awesomatix #P18 AND P19
TRF 420 front hubs
DIFFERENTIALS:
One way diff: #54521
Spool: #54592
Ball diff: #54522
TURNBUCKLES:
Front Toe 3x18mm: #54247
Rear Toe 3x32mm: #54249
Steering Link 3x42mm:#54250
Open Face Ball Ends: #54868
MISCELLANEOUS:
Titanium Screw Set: #47449
Servo mount screws: #54862
POM Spacers: #54855
Carbon front stiffeners: #54962
Aluminum steering arms: #54958
Aluminum steering bridge: #54957
Print Wikipost
Old 03-24-2024, 05:16 PM
  #871
MonkeyCmonkeyDo's Avatar
Quite a fit for electronics. Motor gear cover on initial start up had some rub and tug so I took it off.
working the e car body now. All cut out.
I shoulda ran the car today but no body so no practice with it...didn't matter for another car lol. All well maybe next weekend.
d
MonkeyCmonkeyDo is offline
Old 03-30-2024, 07:06 PM
  #872
Maiden voyage today. Break in day.
The car is dead slow. Like toy car slow. Lol.
Is my only option to throw gearing at it?
Motor stayed cool so confident I can up gearing. Currently at stock gears. 24/63 I think.
thanks for any advice! Info! Tips!
Appreciated.
D
angrymelon likes this.
Old 04-02-2024, 05:36 PM
  #873
Scionara05's Avatar
Appreciated.
D
you are way under geared. Most drivers on an asphalt track are 82 52 start gearing and adjusting from there.
MonkeyCmonkeyDo likes this.
Scionara05 is offline
Old 05-07-2024, 04:53 PM
  #874
Hello,
Someone link me or point me in the direction of decal instructions for the 1997 Mercedes Benz clk gtr from Tamiya?
I got this new body cuz I was told it was legal for tcs now. However I want to paint it blue and do the stock decals.
tia
-d
Old 05-08-2024, 12:31 AM
  #875
zuqbu's Avatar
Try this link. Tamiya Germany has a good repository for manuals.
zuqbu is online now
Old 05-08-2024, 06:17 PM
  #876
Scionara05's Avatar
Hello,
tia
-d
jist a heads up the body is super heavy compared to the gte and le man's bodys
Old 05-08-2024, 07:32 PM
  #877
I'm not a good enough driver/fast enough or exp enough to know or feel the diffence between 100s of grams on body's. Figured this body would plant the rear end more if I needed it. This is me testing. Lol.
If no formula e next weekend I'll run the car in gt2 or whatever tamiya tc class it fits. Why I mainly got the body.
d
