New Tamiya Chassis TC-01 >
Like Tree680Likes
    Hide Wikipost
Old 12-05-2020, 09:50 PM   -   Wikipost
R/C Tech ForumsThread Wiki: New Tamiya Chassis TC-01
Last edit by: RCBuddha
INSTRUCTION MANUALS:
Vehicle instruction manual: https://cdn.simba-dickie-group.de/do...2-car-tc01.pdf
Formula E body instruction manual: https://cdn.simba-dickie-group.de/do...e-gen2-car.pdf
HOPUPS:
DRIVE TRAIN:
• Universal Prop shaft (TC01): #54975
• Double Cardon Prop Shaft (TC01): #54961
• Aluminum spur gear holder: #54903
• Universal shafts: #54515
• Clamp hex hub: #53570 or #53823
• Double cardan shaft: #42360
Double cardan joints (TRF): #42216 (set) & #42239 (42mm shaft)
• Different Aluminum Drive Cup: #54543
• Steel Bevel Differential Gears: #54540
• Gear Differential Steel Cross Shaft: #54533
BEARINGS (in MM):
• 3x6x2.5: x2
• 9x5x3: x1
• 9x5 (flanged): x1
• 5x8x2.5: x12
• 5x10x4: x10
• 5x10x3: x2
• 10x15x4: x4
SCREWS:
• 3x5mm Titanium Hex Head Screws x4
• 3x6mm Titanium Hex Head Screws x6
• 3x8mm Titanium Hex Head Screws x18
• 3x10mm Titanium Hex Head Screws x13
• 3x12mm Titanium Hex Head Screws x12
• 3x6mm Titanium Hex Head Countersunk Screws x5
• 3x8mm Titanium Hex Head Countersunk Screws x10
• 3x10mm Titanium Hex Head Countersunk Screws x8
SUSPENSION:
• Suspension arm mounts (rear skid angle): #54787
• Supension arm mounts: #54760
• Stabilizers: #54956
• Aluminum rocker arms: #54955
• TRF big bore shocks: #42354
• TRF works shocks: #84317
• TRF Special shocks: #42102
• Carbon rear crossmember: #54783
• Carbon front crossmember: #54782
• Low friction suspension balls: #54747
• Titanium Coated suspension shaft: #53581
• Flourine supension balls: #53709
• Titanium Coated Shock Shaft: #54043
• Aluminum shock extenders: #54960
WTCC's adjustable suspension Conversion:
Parts needed:
• 3x23mm turnbuckles (x8)
• Yokomo #BM-206
• Awesomatix #P18 AND P19
• TRF 420 front hubs
DIFFERENTIALS:
• One way diff: #54521
• Spool: #54592
• Ball diff: #54522
TURNBUCKLES:
• Front Toe 3x18mm: #54247
• Rear Toe 3x32mm: #54249
• Steering Link 3x42mm:#54250
• Open Face Ball Ends: #54868
MISCELLANEOUS:
• Titanium Screw Set: #47449
• Servo mount screws: #54862
• POM Spacers: #54855
• Carbon front stiffeners: #54962
• Aluminum steering arms: #54958
• Aluminum steering bridge: #54957
Print Wikipost
Old 10-20-2021, 08:54 AM
  #781
Thanks. I thought the shims only adjust camber as is brings the LCA out while leaving the UCA static? And caster is adjusted when either arms move forward or backward right? Sorry, Im not clear on how the caster is actually adjusted when moving the arm out.
zerovandez is offline
Old 10-21-2021, 01:12 AM
  #782
Regional Moderator
disaster999's Avatar
Yes caster is changed when you move the lower arm forwards or backwards. Camber is changed when you shim the lower suspension mount outwards or inwards.
disaster999 is offline
Old 10-21-2021, 08:31 PM
  #783
Right. So on the tc01 when you add a shim behind suspension hinge pin blocks, you are bring the lower arm outwards to adjust camber. How does this affect caster at all?
Old 10-21-2021, 08:45 PM
  #784
Regional Moderator
It might affect the caster angle, but the difference would be so small, combined with the amount of slop Tamiya car has in their suspension, it really wont matter much. Try putting the same amount of shims behind the suspension block on all 4 corners and put the car on the setup station. I guarantee you the camber will be all out of place. Just make sure the setup is the same left to right and enjoy the car.
zerovandez likes this.
Old 10-21-2021, 10:25 PM
  #785
You are spot on about the suspension slop! Thanks for you responses. Much appreciated.
Old 11-18-2021, 01:18 PM
  #786
Dan
Dan's Avatar
Trader Rating: 74 (100%+)
Rebuilt the diffs with steel gears/cross pins. Praying it holds up, have not even ran a full pack thru my TC-01.
Interesting to note, didn't know Tamiya has an aluminum diff housing option available. part #42324
Dan is offline
Old 11-18-2021, 02:15 PM
  #787
f1larry's Avatar
Trader Rating: 19 (100%+)
Ran mine in the TCS race last weekend. Car was box stock except for springs, spur, and pinion. 3.6 FDR with reedy 21.5 FT. LMP body. Car ran flawlessly the whole weekend.
Qatmix and NutDriver like this.
f1larry is offline
Old 11-19-2021, 07:39 AM
  #788
IAmGreatDane's Avatar
What size spur/pinion did you use and I take it you have been using 64pitch gears?
Thanks.
IAmGreatDane is offline
Old 11-19-2021, 07:56 AM
  #789
simple's Avatar
what was the track surface?
simple is offline
Old 11-19-2021, 10:16 AM
  #790
f1larry's Avatar
Thanks.
64 pitch.
spur/pinion 76/52
IAmGreatDane and NutDriver like this.
f1larry is offline
Old 11-19-2021, 10:17 AM
  #791
f1larry's Avatar
black carpet
simple and NutDriver like this.
f1larry is offline
Old 11-19-2021, 10:44 AM
  #792
NutDriver's Avatar
Trader Rating: 26 (100%+)
What did you run for springs/pistons/oil, Larry?
NutDriver is offline
Old 11-19-2021, 05:18 PM
  #793
f1larry's Avatar
I think I used the kit oil, 3 hole piston, and red hard tuned spring
NutDriver likes this.
f1larry is offline
Old 11-27-2021, 08:43 PM
  #794
GT CRUSING's Avatar
Default VTA on TC-01
So I went ahead and fitted VTA tires onto the TC-01 and it actually works just great. The whole thing weighed in at 1488 grams with the VTA Legal Body and 25.5T motor. I changed the rear body mounts towards the rear bumper to improve reliability as the stock mounts over the shocks I didn't like at all. I also swapped the front hub knuckles for regular touring car aluminum ones with carbon fiber mounts to clear the front tires better than the composite parts.
Handeling wise, this thing was super smooth and very easy to drive, though I did feel it lacked straightaway speed even though I geared it pretty low. I did race this on high grip black carpet and nothing broke on it. I did swap out the internal composite diff for the aluminum one with the metal bits for reliability. With the TC-01's lowered center of gravity, it was very awkward to have alot of open space in the body
Qatmix, simple, MatsNorway and 1 others like this.
GT CRUSING is offline
Old 12-02-2021, 06:23 AM
  #795
British Menace's Avatar
Nice work GT CRUSING.
I was thinking of running a TC-01 in the USGT class.
This class has a 1350 (RTR) min' weight limit.
Any advice on doing this?
I do plan on running 64 pitch gearing. Does the aluminum diff' housings cause a large weight penalty? I am thinking maybe I should just keep to metal internals. What do you think?
Thanks and great work again on the car!
Regards
BM
British Menace is offline
