New Tamiya Chassis TC-01 >
Like Tree680Likes
    Hide Wikipost
Old 12-05-2020, 09:50 PM   -   Wikipost
R/C Tech ForumsThread Wiki: New Tamiya Chassis TC-01
Last edit by: RCBuddha
INSTRUCTION MANUALS:
Vehicle instruction manual: https://cdn.simba-dickie-group.de/do...2-car-tc01.pdf
Formula E body instruction manual: https://cdn.simba-dickie-group.de/do...e-gen2-car.pdf
HOPUPS:
DRIVE TRAIN:
• Universal Prop shaft (TC01): #54975
• Double Cardon Prop Shaft (TC01): #54961
• Aluminum spur gear holder: #54903
• Universal shafts: #54515
• Clamp hex hub: #53570 or #53823
• Double cardan shaft: #42360
Double cardan joints (TRF): #42216 (set) & #42239 (42mm shaft)
• Different Aluminum Drive Cup: #54543
• Steel Bevel Differential Gears: #54540
• Gear Differential Steel Cross Shaft: #54533
BEARINGS (in MM):
• 3x6x2.5: x2
• 9x5x3: x1
• 9x5 (flanged): x1
• 5x8x2.5: x12
• 5x10x4: x10
• 5x10x3: x2
• 10x15x4: x4
SCREWS:
• 3x5mm Titanium Hex Head Screws x4
• 3x6mm Titanium Hex Head Screws x6
• 3x8mm Titanium Hex Head Screws x18
• 3x10mm Titanium Hex Head Screws x13
• 3x12mm Titanium Hex Head Screws x12
• 3x6mm Titanium Hex Head Countersunk Screws x5
• 3x8mm Titanium Hex Head Countersunk Screws x10
• 3x10mm Titanium Hex Head Countersunk Screws x8
SUSPENSION:
• Suspension arm mounts (rear skid angle): #54787
• Supension arm mounts: #54760
• Stabilizers: #54956
• Aluminum rocker arms: #54955
• TRF big bore shocks: #42354
• TRF works shocks: #84317
• TRF Special shocks: #42102
• Carbon rear crossmember: #54783
• Carbon front crossmember: #54782
• Low friction suspension balls: #54747
• Titanium Coated suspension shaft: #53581
• Flourine supension balls: #53709
• Titanium Coated Shock Shaft: #54043
• Aluminum shock extenders: #54960
WTCC's adjustable suspension Conversion:
Parts needed:
• 3x23mm turnbuckles (x8)
• Yokomo #BM-206
• Awesomatix #P18 AND P19
• TRF 420 front hubs
DIFFERENTIALS:
• One way diff: #54521
• Spool: #54592
• Ball diff: #54522
TURNBUCKLES:
• Front Toe 3x18mm: #54247
• Rear Toe 3x32mm: #54249
• Steering Link 3x42mm:#54250
• Open Face Ball Ends: #54868
MISCELLANEOUS:
• Titanium Screw Set: #47449
• Servo mount screws: #54862
• POM Spacers: #54855
• Carbon front stiffeners: #54962
• Aluminum steering arms: #54958
• Aluminum steering bridge: #54957
Print Wikipost
Old 04-24-2020, 11:21 AM
  #61
OPY
Originally Posted by walrusjon View Post
TC-01 Length 430mm ,width 188mm,height 99mm, wheelbase 257mm.
But full scale is 5160mm , 1770mm, 1050mm and 3100mm
OPY is offline
Old 04-24-2020, 11:22 AM
  #62
simple's Avatar
So geeked, I can't wait to build this!!!
the CLASS MAKER strikes again!
DavidNERODease likes this.
Last edited by simple; 04-24-2020 at 11:29 AM. Reason: didn't want to use the litigious other "T" companies name.....
simple is offline
Old 04-24-2020, 11:54 AM
  #63
Billy Kelly's Avatar
Originally Posted by Speed Chaser View Post
I would wait until Monday in the Japanese Tamiya site they say more information about it will be announced on the 27. They will also be having a live broadcast about it on the 26. Link and here is a link to their Japanese youtube Link
I’ll wait till I see a listing in the states. Overseas orders are not my choice anymore.
Billy Kelly is offline
Old 04-24-2020, 11:55 AM
  #64
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
OSherman, Raman and wtcc like this.
Phat-Boy is offline
Old 04-24-2020, 12:16 PM
  #65
Speed Chaser's Avatar
I didn't say to order overseas I just said to wait to see what they announce.
Originally Posted by Phat-Boy View Post
Got a link
Speed Chaser is offline
Old 04-24-2020, 01:04 PM
  #66
Phat-Boy's Avatar
Got a link
https://m.facebook.com/story.php?sto...08099459316998
Phat-Boy is offline
Old 04-24-2020, 01:20 PM
  #67
Got a link
I’m sure the YouTube video will be in Japanese. Pretty much seen what I needed
Old 04-24-2020, 01:49 PM
  #68
Ok? Was the video the only thing I listed? nope, I also said that they will have an announcement on the 27 on their site which google translate can be used on and I sure several people here will post it translated anyways. Plus their youtube has an auto-translate option to English.
gigaplex likes this.
Old 04-24-2020, 02:21 PM
  #69
I’ll follow here. Never figured out the translator thing. I’ve seen by the pictures pretty much what I needed to see.
Old 04-24-2020, 02:27 PM
  #70
IndyRC_Racer's Avatar
I owned and raced the F201 on different surfaces (asphalt parking lots, dedicated asphalt track at a TCS race & gray ozite carpet at club & TCS races). There were only 3 things that were an issue on the box stock car...
1 - Only 2 gearing options - hopefully the TC-01 will have more gearing options like the TT-01 or TT-02 vehicles
2 - Weak front lower a-arms - Tamiya eventually released better a-arms, but it looks like the TC-01 is a better design.
3 - Limited wheel/tire options. - Since the TC-01 appears to use TC tires, that shouldn't be an issue.
Of course there were quirks with the F201, but the car could be tuned and raced very successfully. The only thing that I really didn't like on the F201 was the location of the servo. However with the TC-01 it looks like it should be easy to access or replace it if you have any problems.
I actually don't mind the unique bath tub style car that Tamiya has released. I am currently racing a TA-07 and I don't find it any more difficult to work on than any other belt or shaft drive cars that I've owned.
Phat-Boy likes this.
IndyRC_Racer is offline
Old 04-24-2020, 04:58 PM
  #71
GT CRUSING's Avatar
Definately gonna try out the FGX wheels on this and see if i can fit an F1 body on it
GT CRUSING is offline
Old 04-24-2020, 07:07 PM
  #72
FMW
FMW's Avatar
Originally Posted by Nicadrauspro4 View Post
Looks like an F-E. But when you hear or read the abbreviation "TC", Touring Car comes to mind first. So If it ain't a touring car chassis, they should re-name it to something else like "TE" or "TF".
TA (There have been 7 in the series thus far)
TB (There have been 5 in the series thus far)
TC (That's the new designation for a new platform series) TC-02, TC-03 TC-04 etc....
TD (10 years into the future) These will be perpetual motion 4WD R/C chassis cars.
OSherman likes this.
FMW is offline
Old 04-24-2020, 07:58 PM
  #73
Haha! I would like to fit the FE body to a proper traditional F1 chassis like my TRF103 but seems difficult due to 15mm difference of wheelbase. A F103GT body would definitely fit on TC-01 since they have same wheelbase, so a TS050 on this can also be a good idea.
herrokero likes this.
riddic is offline
Old 04-25-2020, 10:27 AM
  #74
fat500's Avatar
Trader Rating: 45 (100%+)
Hey Everyone......This is a TOURING car chassis not a F1.......no comparison to the f201 which was a 4wd F1 only chassis.
This uses Standard TC wheels TB05 Drivetrain with a newly designed Suspension......EVEN comes with the front bumper to run a tc body in the box. If they would have released the chassis set without the body the presentation would have been much better as that class of racing is not very popular. Imagine a trf version of this........Wow.......
fat500 is offline
Old 04-25-2020, 11:47 AM
  #75
OSherman's Avatar
in a way we are all correct.. hence it being a 'new platform'
OSherman is offline
