New Tamiya Chassis TC-01 >
Like Tree778Likes
    Hide Wikipost
Old 12-05-2020, 09:50 PM   -   Wikipost
R/C Tech ForumsThread Wiki: New Tamiya Chassis TC-01
Last edit by: RCBuddha
INSTRUCTION MANUALS:
Vehicle instruction manual: https://cdn.simba-dickie-group.de/do...2-car-tc01.pdf
Formula E body instruction manual: https://cdn.simba-dickie-group.de/do...e-gen2-car.pdf
HOPUPS:
DRIVE TRAIN:
• Universal Prop shaft (TC01): #54975
• Double Cardon Prop Shaft (TC01): #54961
• Aluminum spur gear holder: #54903
• Universal shafts: #54515
• Clamp hex hub: #53570 or #53823
• Double cardan shaft: #42360
• Double cardan joints (TRF): #42216 (set) & #42239 (42mm shaft)
• Different Aluminum Drive Cup: #54543
• Steel Bevel Differential Gears: #54540
• Gear Differential Steel Cross Shaft: #54533
BEARINGS (in MM):
• 3x6x2.5: x2
• 9x5x3: x1
• 9x5 (flanged): x1
• 5x8x2.5: x12
• 5x10x4: x10
• 5x10x3: x2
• 10x15x4: x4
SCREWS:
• 3x5mm Titanium Hex Head Screws x4
• 3x6mm Titanium Hex Head Screws x6
• 3x8mm Titanium Hex Head Screws x18
• 3x10mm Titanium Hex Head Screws x13
• 3x12mm Titanium Hex Head Screws x12
• 3x6mm Titanium Hex Head Countersunk Screws x5
• 3x8mm Titanium Hex Head Countersunk Screws x10
• 3x10mm Titanium Hex Head Countersunk Screws x8
SUSPENSION:
• Suspension arm mounts (rear skid angle): #54787
• Supension arm mounts: #54760
• Stabilizers: #54956
• Aluminum rocker arms: #54955
• TRF big bore shocks: #42354
• TRF works shocks: #84317
• TRF Special shocks: #42102
• Carbon rear crossmember: #54783
• Carbon front crossmember: #54782
• Low friction suspension balls: #54747
• Titanium Coated suspension shaft: #53581
• Flourine supension balls: #53709
• Titanium Coated Shock Shaft: #54043
• Aluminum shock extenders: #54960
WTCC's adjustable suspension Conversion:
Parts needed:
• 3x23mm turnbuckles (x8)
• Yokomo #BM-206
• Awesomatix #P18 AND P19
• TRF 420 front hubs
DIFFERENTIALS:
• One way diff: #54521
• Spool: #54592
• Ball diff: #54522
TURNBUCKLES:
• Front Toe 3x18mm: #54247
• Rear Toe 3x32mm: #54249
• Steering Link 3x42mm:#54250
• Open Face Ball Ends: #54868
MISCELLANEOUS:
• Titanium Screw Set: #47449
• Servo mount screws: #54862
• POM Spacers: #54855
• Carbon front stiffeners: #54962
• Aluminum steering arms: #54958
• Aluminum steering bridge: #54957
Print Wikipost
Old 04-24-2020, 06:53 AM
  #46
OPY
It looks great except the fact that Tamiya sacrificed scale realism to accommodate the touring car platform
Wheelbase should be 310mm and width should be less than 180mm
OPY is offline
Old 04-24-2020, 06:57 AM
  #47
TC body war over - Tamiya wins
simple likes this.
DavidNERODease is offline
Old 04-24-2020, 07:07 AM
  #48
Awaiting for the ms, r spec or Trf spec coming out.
Exo skeleton is a pain to install the electronics. But TA07 and TB05 have done it in a way making the concept work. This , however, reminds me of my TA06, which requires removing 10plus screws and dismantle the rear end to gaik access to diff...
zxcvb1t is offline
Old 04-24-2020, 07:10 AM
  #49
Tamiya always wins! The orange (now black ) , black and red have less titles between them than a toy company.
zxcvb1t is offline
Old 04-24-2020, 07:31 AM
  #50
OSherman's Avatar
Carbon DualDeck Chassis, RWD only, ShortyPack, Proper F1 body..
This could be multipurpose..
If they don't do it, someone else will
OSherman is offline
Old 04-24-2020, 08:01 AM
  #51
sugs's Avatar
I like it, definitely will make a fun spec class.
sugs is offline
Old 04-24-2020, 09:26 AM
  #52
walrusjon's Avatar
TC-01 Length 430mm ,width 188mm,height 99mm, wheelbase 257mm.
Phat-Boy likes this.
walrusjon is offline
Old 04-24-2020, 09:31 AM
  #53
Speed Chaser's Avatar
Any idea on price? I figure something in the 200 to 250 range
Speed Chaser is offline
Old 04-24-2020, 09:35 AM
  #54
walrusjon's Avatar
Its JPY ₯27800 will be released on coming July
Old 04-24-2020, 09:40 AM
  #55
Yeap just found this photo on it
So it is around 260 USD currently, not a bad price. I see that it list some TB-04 and M-07 parts.
Phat-Boy and walrusjon like this.
Old 04-24-2020, 09:41 AM
  #56
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
Will Tamiya Group C car bodies or Porsche 911 GT1 F103gt body fit without modification?
Phat-Boy is offline
Old 04-24-2020, 09:55 AM
  #57
walrusjon's Avatar
It can use some tb04 and m07 parts for TC01
Old 04-24-2020, 10:04 AM
  #58
The bottom section where it talks about touring car body, does it comes with those parts straight from the kit, or is it something you buy separately? Foam bumper, mount, rear bumper, and body post.
Old 04-24-2020, 10:10 AM
  #59
Billy Kelly's Avatar
I can’t find an actual listing for it yet. Link on BigSquid just goes to Tamiya America which does not have a listing for it.
Billy Kelly is offline
Old 04-24-2020, 10:18 AM
  #60
I would wait until Monday in the Japanese Tamiya site they say more information about it will be announced on the 27. They will also be having a live broadcast about it on the 26. Link and here is a link to their Japanese youtube Link
