New Tamiya Chassis TC-01 >
Like Tree682Likes
    Hide Wikipost
Old 12-05-2020, 09:50 PM   -   Wikipost
R/C Tech ForumsThread Wiki: New Tamiya Chassis TC-01
Last edit by: RCBuddha
INSTRUCTION MANUALS:
Vehicle instruction manual: https://cdn.simba-dickie-group.de/do...2-car-tc01.pdf
Formula E body instruction manual: https://cdn.simba-dickie-group.de/do...e-gen2-car.pdf
HOPUPS:
DRIVE TRAIN:
• Universal Prop shaft (TC01): #54975
• Double Cardon Prop Shaft (TC01): #54961
• Aluminum spur gear holder: #54903
• Universal shafts: #54515
• Clamp hex hub: #53570 or #53823
• Double cardan shaft: #42360
Double cardan joints (TRF): #42216 (set) & #42239 (42mm shaft)
• Different Aluminum Drive Cup: #54543
• Steel Bevel Differential Gears: #54540
• Gear Differential Steel Cross Shaft: #54533
BEARINGS (in MM):
• 3x6x2.5: x2
• 9x5x3: x1
• 9x5 (flanged): x1
• 5x8x2.5: x12
• 5x10x4: x10
• 5x10x3: x2
• 10x15x4: x4
SCREWS:
• 3x5mm Titanium Hex Head Screws x4
• 3x6mm Titanium Hex Head Screws x6
• 3x8mm Titanium Hex Head Screws x18
• 3x10mm Titanium Hex Head Screws x13
• 3x12mm Titanium Hex Head Screws x12
• 3x6mm Titanium Hex Head Countersunk Screws x5
• 3x8mm Titanium Hex Head Countersunk Screws x10
• 3x10mm Titanium Hex Head Countersunk Screws x8
SUSPENSION:
• Suspension arm mounts (rear skid angle): #54787
• Supension arm mounts: #54760
• Stabilizers: #54956
• Aluminum rocker arms: #54955
• TRF big bore shocks: #42354
• TRF works shocks: #84317
• TRF Special shocks: #42102
• Carbon rear crossmember: #54783
• Carbon front crossmember: #54782
• Low friction suspension balls: #54747
• Titanium Coated suspension shaft: #53581
• Flourine supension balls: #53709
• Titanium Coated Shock Shaft: #54043
• Aluminum shock extenders: #54960
WTCC's adjustable suspension Conversion:
Parts needed:
• 3x23mm turnbuckles (x8)
• Yokomo #BM-206
• Awesomatix #P18 AND P19
• TRF 420 front hubs
DIFFERENTIALS:
• One way diff: #54521
• Spool: #54592
• Ball diff: #54522
TURNBUCKLES:
• Front Toe 3x18mm: #54247
• Rear Toe 3x32mm: #54249
• Steering Link 3x42mm:#54250
• Open Face Ball Ends: #54868
MISCELLANEOUS:
• Titanium Screw Set: #47449
• Servo mount screws: #54862
• POM Spacers: #54855
• Carbon front stiffeners: #54962
• Aluminum steering arms: #54958
• Aluminum steering bridge: #54957
Print Wikipost
Old 06-26-2020, 06:06 AM
  #316
tygertyger's Avatar
Originally Posted by GT CRUSING View Post
You can always count on a mayor oversight by tamiya, just like the M07 motor wiring blocked by the chassis, looks like on this car they didn't even think of how common batteries are wired. [...] Just realized that you arent gonna be able to run a standard shorty bullet plug lipo on this...the chassis brackets are in the way All over the top
Not entirely sure this is going to be an issue from what we can see on the pictures; but I agree this would be such a Tamiya thing to do. Thankfully with recessed tubes on the battery and low-profile plugs, none of this should be a dealbreaker. Potentially irritating... for sure.
simple likes this.
tygertyger is offline
Old 06-26-2020, 09:04 AM
  #317
Raman's Avatar
Trader Rating: 85 (100%+)
On the M08, I was severely frustrated that they had not planned for a shorty pack.. no proper mount, no room for bullets. Then TCS happened and I went to weight my car and I was way under 1300g .. so I ended up having to run standard Lipo and still add weights.
Raman is offline
Old 06-26-2020, 01:26 PM
  #318
IndyRC_Racer's Avatar
Thanks for providing the link for the rounded case Protek battery. That should work well in kits that need or can take advantage of these types of batteries.
In the past I've purchased Reedy Wolfpack or Orion Rocket batteries for my Tamiya cars. The only issue with these batteries is they have been lower mah & C ratings. Here are a couple of links.
Reedy Wolfpack 3300 mah lipo - https://www.associatedelectrics.com/...0mah_30c_7_4v/
Reedy Wolfpack 4000 mah lipo - https://www.associatedelectrics.com/...0mah_35c_7_4v/
Orion Rocket batteries - https://teamorion.com/en/batteries-en/lipo/hobby-stick/
There are several other companies that make or sell rounded lipo packs, but I've had good experience running batteries from Reedy and Orion in my Tamiya cars.
IndyRC_Racer is offline
Old 06-26-2020, 02:03 PM
  #319
DaSilva3525's Avatar
Forget that... no round packs should ever be used in 2020 lol. My first M05 was the non V2 version and I remember taking a dremel right away to the battery compartment to square it out before I built it. Worked like a charm and that was an extreme amount of material versus this new kit stuff. I'm sure the battery tray will be fine for the lipo and minor modifying for the bullets if anything.
DaSilva3525 is offline
Old 06-26-2020, 03:51 PM
  #320
You shouldn't have to run a round shaped lipo in the TC-01, but you can run one if you want. But if you race in the Tamiya Euro Truck class or have older Tamiya vehicles, it is nice to have a battery that you can use in all of those vehicles.
Old 07-01-2020, 11:07 AM
  #321
angrymelon's Avatar
Unboxing video:
angrymelon is offline
Old 07-01-2020, 01:20 PM
  #322
Originally Posted by JJ100179 View Post
+1 on this
Call me crazy, but I have already ordered a TSU-06 servo (they are currently on sale at one of the well-known german rc online shops) and actually managed to source a TBLE-03S ESC to do a "Box Art TC-01" .
Maybe I'm lucky and can trace one of these Tamiya LF 2200 batteries. It seems that they are nearly impossible to find in Europe. Would be cool if someone can help me!
​​​​​​Michael
​​​​​​Here is an update, maybe someone is interested...
I was actually able to get one of the LF1600 batteries from ebay. It costs me a little fortune (don't tell my wife...), but to be honest it is a nice and very well done little battery.
I am planning to realize some 3d printed copies of the LF battery's case and do my own 2200 mAh LiFePo batteries using four 1100mAh 18650 cells combined to a 2S2P pack.
​​I have already build a bunch of 2S and 3S LiFePo battery packs out of 26650 cells. A123 or nowadays Lithium Werks cells do a surprisingly good job in powering a RC car.
​​​​​So, i'm sure that the new selfmade 2200mAh packs will be pretty fine to get the TC-01 running decently with a Tamiya TBLM-02S brushless motor (either 15.5 or 17.5 turns).
JJ100179 is offline
Old 07-03-2020, 04:02 PM
  #323
Looking forward to getting this. I'm an F1 follower since the 1970s, but more and more it seems not as exciting as it used to be. So I watch Indycar and Formula-e too.
I don't understand marketing these days. Seems like the series are shooting themselves in the foot by charging for licensing.
I recall in the 1970s building many F1 cars (Tamiya kits!) before I was old enough to go to an F1 race. I was already hooked as a kid.
BTW, I built this in 1976 and recently restored it. By the time I got to my first F1 race (Indy 2000), this car was in the Vintage class.
ic-racer is offline
Old 07-04-2020, 09:00 AM
  #324
Raman's Avatar
Absolutely stunning. Kit like that today would cost $1k probably
Raman is offline
Old 07-04-2020, 02:19 PM
  #325
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
from the video
RCBuddha is offline
Old 07-06-2020, 05:56 AM
  #326
simple's Avatar
The issue in question is not the profile, or the opening...
Its access to the TOP of the Lipo when its installed.
Its clear to me this will not be answered until someone has a kit assembled in hand with corresponding square Lipo that has bullet connector tubes.
Processing my PreOrder anyways.
simple is offline
Old 07-06-2020, 11:58 AM
  #327
I have a M07 and a standard battery fits with space for the plug-ins. The pictures seem to show the TC-01 will be the same.
angrymelon and simple like this.
ic-racer is offline
Old 07-06-2020, 12:20 PM
  #328
Pictures of the battery end holders , however, suggest the TC-01 battery holder might be just a little narrower than the part for the M07, with less room for the connectors. Otherwise, maybe they would have used the exact same part. If that is the case, only official Tamiya racing would likely prevent one from using the M07 battery holders.
ic-racer is offline
Old 07-06-2020, 12:58 PM
  #329
Wow, this thread is full of a bunch of babies. If the battery you want to use doesn't fit, it isn't against the law to modify the car to make it work. None of you would have made it in the early days of the hobby where you had to make stuff work yourself.
And don't give me any TCS BS either. That is a single event, and the entire existence of this car does not revolve around TCS rules.
Tamiya does some questionable things with their verticle integration (non-standard LiFe batteries, supplying a brushless esc while including a brushed motor, continuing to utilize JIS screws), but that doesn't mean you have to drink their weird koolaid. I get the nostalgia of Tamiya stuff, but the rc industry has moved on. If you want to use normal electronics you can, it won't end the world.
waitwhat is offline
Old 07-07-2020, 04:36 AM
  #330
simple's Avatar
This whining baby doesn't like to have to modify to suit "industry standard" components, especially when holding Tamiya to a higher standard of kit build. Not to mention the hard earned money spent. Their product should be right on all accounts the first time. Its the standard that they have set.
I'd also prefer not to have to explain in the future, if I decide to sell, why I chewed up the chassis and battery retaining clips.....All speculation of course, because that it IS WHAT THE FORUM IS FOR!
...another useless contributor added to the ignore list.....
Billy Kelly and gigaplex like this.
simple is offline
