New Tamiya Chassis TC-01 >
Like Tree778Likes
    Hide Wikipost
Old 12-05-2020, 09:50 PM   -   Wikipost
R/C Tech ForumsThread Wiki: New Tamiya Chassis TC-01
Last edit by: RCBuddha
INSTRUCTION MANUALS:
Vehicle instruction manual: https://cdn.simba-dickie-group.de/do...2-car-tc01.pdf
Formula E body instruction manual: https://cdn.simba-dickie-group.de/do...e-gen2-car.pdf
HOPUPS:
DRIVE TRAIN:
• Universal Prop shaft (TC01): #54975
• Double Cardon Prop Shaft (TC01): #54961
• Aluminum spur gear holder: #54903
• Universal shafts: #54515
• Clamp hex hub: #53570 or #53823
• Double cardan shaft: #42360
• Double cardan joints (TRF): #42216 (set) & #42239 (42mm shaft)
• Different Aluminum Drive Cup: #54543
• Steel Bevel Differential Gears: #54540
• Gear Differential Steel Cross Shaft: #54533
BEARINGS (in MM):
• 3x6x2.5: x2
• 9x5x3: x1
• 9x5 (flanged): x1
• 5x8x2.5: x12
• 5x10x4: x10
• 5x10x3: x2
• 10x15x4: x4
SCREWS:
• 3x5mm Titanium Hex Head Screws x4
• 3x6mm Titanium Hex Head Screws x6
• 3x8mm Titanium Hex Head Screws x18
• 3x10mm Titanium Hex Head Screws x13
• 3x12mm Titanium Hex Head Screws x12
• 3x6mm Titanium Hex Head Countersunk Screws x5
• 3x8mm Titanium Hex Head Countersunk Screws x10
• 3x10mm Titanium Hex Head Countersunk Screws x8
SUSPENSION:
• Suspension arm mounts (rear skid angle): #54787
• Supension arm mounts: #54760
• Stabilizers: #54956
• Aluminum rocker arms: #54955
• TRF big bore shocks: #42354
• TRF works shocks: #84317
• TRF Special shocks: #42102
• Carbon rear crossmember: #54783
• Carbon front crossmember: #54782
• Low friction suspension balls: #54747
• Titanium Coated suspension shaft: #53581
• Flourine supension balls: #53709
• Titanium Coated Shock Shaft: #54043
• Aluminum shock extenders: #54960
WTCC's adjustable suspension Conversion:
Parts needed:
• 3x23mm turnbuckles (x8)
• Yokomo #BM-206
• Awesomatix #P18 AND P19
• TRF 420 front hubs
DIFFERENTIALS:
• One way diff: #54521
• Spool: #54592
• Ball diff: #54522
TURNBUCKLES:
• Front Toe 3x18mm: #54247
• Rear Toe 3x32mm: #54249
• Steering Link 3x42mm:#54250
• Open Face Ball Ends: #54868
MISCELLANEOUS:
• Titanium Screw Set: #47449
• Servo mount screws: #54862
• POM Spacers: #54855
• Carbon front stiffeners: #54962
• Aluminum steering arms: #54958
• Aluminum steering bridge: #54957
Print Wikipost
Old 04-22-2020, 05:11 AM
  #16
Fortmula E is the full-size version of what everyone on this forum "Electric On-Road" does. RC F1 cars should have nitro or gas engines. I'm surprised it took this long to get interest in Formula-E RC car.
gigaplex likes this.
ic-racer is offline
Old 04-22-2020, 08:09 AM
  #17
Tc01pro or basic kit with cva damper will be released?
zxcvb1t is offline
Old 04-22-2020, 08:33 AM
  #18
Billy Kelly's Avatar
I’ve emailed the body companies about doing a formulaE body before. Never got a response.
I’m usually not interested in Tamiya, but I’ll wait a see. The could have just done a body a formulaE body that fits a tt01.
Billy Kelly is offline
Old 04-22-2020, 10:36 AM
  #19
IndyRC_Racer's Avatar
There are fuel powered R/C F1 vehicles that exist, but they are normally larger than 1/10 scale and they have been around for years. For example Kyosho has fueled powered R/C F1 vehicles with some models being over 20 years old. Unfortunately due to the size of the vehicles and the noise/fumes it isn't always practical to race these vehicles at every venue. R/C racing doesn't always need to be an exact representation of full sized racing.
Below is youtube video from 2019 of 1/5 scale fuel powered R/C F1 vehicles being raced.
IndyRC_Racer is offline
Old 04-22-2020, 11:00 AM
  #20
I don't think you could fit a low slung body over the shock towers on most touring cars such as a Tamiya TT-01. There are several existing 4wd Tamiya on-road kits that do have inboard front suspension (IFS) that can use very low profile bodies in the front (TB-03, TB-04, TA-05, TA-06, others?) These probably would be a better option if you were going to convert an existing touring car. I will be interested to see what the actual chassis looks like. Hopefully it will share suspension parts with existing Tamiya kits.
Billy Kelly likes this.
Old 04-22-2020, 11:21 AM
  #21
Trader Rating: 16 (100%+)
It could be F201 update?
OSherman likes this.
TamiyaW1688 is offline
Old 04-22-2020, 04:10 PM
  #22
Herc Driver's Avatar
I’m interested...loved my 201
Herc Driver is offline
Old 04-22-2020, 05:02 PM
  #23
F1fletch's Avatar
They are using an F1 tamiya chassis in the workshop as the basis for the car but undoubtedly they are making the most of all the R&D that went into the body.
F1fletch is offline
Old 04-23-2020, 03:11 PM
  #24
Airwave's Avatar
seems as bad as the real Formula E... At least last year...
ABS body? 4wd? I feel a successor of the TL-01...
JatoTheRipper likes this.
Airwave is offline
Old 04-23-2020, 07:45 PM
  #25
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
JoeyE, angrymelon, sugs and 2 others like this.
Phat-Boy is offline
Old 04-23-2020, 07:49 PM
  #26
OOO looks like a F201 Style chassis
herrokero is offline
Old 04-23-2020, 08:01 PM
  #27
OSherman's Avatar
WANT!!
angrymelon likes this.
OSherman is offline
Old 04-23-2020, 08:26 PM
  #28
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Phat-Boy
Nice!
RCBuddha is offline
Old 04-23-2020, 08:42 PM
  #29
I wonder why TC01? It looks like it has F201 style pushrod suspension. And it’s a Formula type body. Wouldn’t F202 or F301 make more sense? Then again, I still think the TA03 and TB01 we’re switched at birth and given the wrong names. 🤪
viking44 is offline
Old 04-23-2020, 09:01 PM
  #30
Well it's running touring car tyres so maybe they didn't want to restrict the chassis to Formula bodies
Phat-Boy, Woulvesbaine and Eotz like this.
