C hub top hat issues >
Like Tree3Likes
  • 1 Post By casrcr
  • 1 Post By terry.sc
  • 1 Post By malkiy
Old 04-13-2020, 02:15 PM
Trader Rating: 30 (100%+)
Default C hub top hat issues
i have hand issues and the top hats that go inside of the c hubs keep falling out...i tried using shock fluid on to keep them from falling out...no luck...anybody super glue them in place ?
thefnshow is offline
Old 04-13-2020, 03:32 PM
SteveM's Avatar
Trader Rating: 160 (100%+)
Falling out when assembling?
SteveM is online now
Old 04-13-2020, 04:34 PM
Trader Rating: 37 (100%+)
I wouldn't use any type of glue, if you need something to hold them in, try a thicker silicone grease. Like ball diff grease or thicker.
chensleyrc1 is offline
Old 04-13-2020, 05:13 PM
Iíll repeat whatís been said, NO GLUE. Try laying the chassis on itís side, obviously with the side youíre assembling pointing up. Take gravity out of the equation.
IndyRC_Racer likes this.
casrcr is offline
Old 04-13-2020, 05:56 PM
just doing the c hubs by themselves...i'll try the thicker grease
Old 04-13-2020, 05:58 PM
+1
Desir100 is offline
Old 04-13-2020, 07:06 PM
SteveM's Avatar
I have never used anything to hold the top hat tubes on in place in a C-hub, not even when the kit calls for a spacer between the steering arm and top hat. It's a simple thing really.
Old 04-15-2020, 02:38 AM
I wouldn't try gluing them in, the steering works by the top hats rotating in the C hub, not the screws rotating in the top hats. Put the C hub on its side so the two ends are pointing up, fit the top hats and drop the steering arm into the gap. No way for them to fall out.
SteveM likes this.
terry.sc is offline
Old 04-15-2020, 07:50 AM
Tamiya anti-wear grease should keep those in place. It's a very thick sticky grease.
Sir 51D3WAYS likes this.
malkiy is offline
Old 04-15-2020, 03:01 PM
Airwave's Avatar
Insert them horizontally?
Airwave is offline
