Old 03-17-2006, 10:22 PM   #1
Michael Barch's Avatar
Send a message via AIM to Michael Barch
Default Motor O-Ring?
Ok, I will take it to a thread so more people can check it and hopefully help me out instend of those just in the T2 thread.
I finished in first, but as soon as I passed the finish line I got hit by someone coming and my car stoped going. I took a look at the Motor O-Ring that holds the endbell stuff (bearing, and all that) and it was half-way out, thus causing my motor to stop. I took a small screw driver and poped it back into place. I took the A main in first with it, then I looked at it after the race and it started to come out just a little bit agian.
Anyone else have this problem with this motor? (Element 19T V2). I asked up front if they sell just the O-Ring, because I take it it's too weak and streched out now, but they don't sell them without buying the entire Endbell kit, which is more than the motor itself...
Does anyone know where I could find one?
Thanks,
Mike
Michael Barch is offline   Reply With Quote
Old 03-17-2006, 10:41 PM   #2
tom235's Avatar
i hve the same thing going on with a 11x2 and no one has them i think we have to go back to who made the motor (orion)
tom235 is offline   Reply With Quote
Old 03-17-2006, 11:25 PM   #3
Suspended
racingkd's Avatar
Send a message via MSN to racingkd Send a message via Yahoo to racingkd
Are you talking about the metal ring in between the can and the endbell? you can PM me if you have any Q's. I would be happy to help!!
racingkd is offline   Reply With Quote
Old 03-17-2006, 11:40 PM   #4
No, it's the rubber O-ring that seals in front of the endbell and metal.
Hmm, I guess I could try and get ahold of Orion tomorrow. Im emailing them now.
Old 03-18-2006, 01:07 AM   #5
Robfo's Avatar
When i used to run an xray i'm sure i replaced on of those o rings with an xray o ring, must have been from the shocks on the evo2, fko4 or fk05. i'll have a look at my old spares and see if i can work it out.
Robfo is offline   Reply With Quote
Old 03-18-2006, 02:45 AM   #6
XrayFK's Avatar
You can just use motor shims instead, the rubber o-ring is supposed to reduce vibrations.
XrayFK is offline   Reply With Quote
Old 03-18-2006, 01:06 PM   #7
How would I go about fitting a shim in the slot though (from the outside)?
Old 03-18-2006, 01:49 PM   #8
You mean the large O-ring that secure the ball bearing, Peak(same as Orion) sells them, PEK2454, 9mm o-ring(10 pieces).
caveman is offline   Reply With Quote
Old 03-18-2006, 01:52 PM   #9
Thanks, found it.
http://www.rcmart.com/catalog/produc...ducts_id=16916
Old 03-18-2006, 02:26 PM   #10
motorhead's Avatar
try eddie 0 from team brood he sould have them
motorhead is offline   Reply With Quote
Old 03-18-2006, 02:33 PM   #11
Mike Haynes's Avatar
You could also go to the local hardware store and get a metal snap ring that size.
It would be much more durable.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 03-18-2006, 08:48 PM   #12
I think Im going to just do that.
Wedding ring 2k. tblaster45 Other Items: For Sale/Trade or Wanted to Buy 2 02-08-2008 08:49 PM
Ring Tones!!! tmail55 Chat Lounge 2 08-25-2007 08:19 PM
RING THAT BELL Leodis Chat Lounge 11 08-23-2007 07:50 AM
IRS D-Ring diff disaster999 Electric On-Road 0 01-19-2004 11:21 PM
