Tamiya M-03 vs. M-07 speed >
Like Tree1Likes
  • 1 Post By gigaplex
Old 03-25-2020, 07:58 PM
Default Tamiya M-03 vs. M-07 speed
I've been running an M-03 with Tekin Gen2 21.5 motor, Tamiya TBLE-02s esc, and 20T pinion.
Recently I built an M-07 with Reedy Mach3 21.5 motor, Tamiya TBLE-02s esc, and 20T pinion.
The M-07's top speed is significantly less than the M-03.
Any ideas why?
Tomoz is offline
Old 03-25-2020, 08:35 PM
tak4's Avatar
Do both cars have the same Internal Drive Ratio and are you using the same spur gear?
Calculate the FDR (Spur/Pinion X Internal Drive Ratio) and make sure they are the same. If the speed difference is till quite big then check to see if the M-07 rolls smoothly. There could be something that is binding or causing rolling resistance.
tak4 is offline
Old 03-25-2020, 09:52 PM
gigaplex's Avatar
You don't appear to have much familiarity with the Tamiya M chassis cars. They only have one spur gear option, it's not compatible with typical spurs. They have the same (rough) internal ratio.
It's most likely a binding issue (new bearings don't roll as freely initially) or an ESC calibration issue. Or the fact they're using two different motors.
gigaplex is offline
Old 03-25-2020, 09:55 PM
gigaplex's Avatar
Any ideas why?
Try swapping the motors between the cars to see if the M07 goes faster and the M03 goes slower.
rcguyfpr likes this.
gigaplex is offline
Old 03-26-2020, 02:38 AM
PizzaDude's Avatar
What giga said
+1
PizzaDude is offline
Old 03-26-2020, 08:21 AM
Thank you -- are you pretty sure the IDR for M-03 and M-07 are roughly the same? The M-07 manual lists the IDR but the M-03 doesn't.
Tomoz is offline
Old 03-26-2020, 09:44 AM
IndyRC_Racer's Avatar
Gigaplex has the simplest solution - swap motors and see if the differences in speed follow the motor.
It also wouldn't hurt to swap batteries between cars. A bad/weak battery can affect top speed of a car
Other things to consider...
- Make sure the slow car doesn't have any mechanical issues
- Make sure both cars are using the exact same tires
- Make sure both cars are using the same transmitter settings such as throttle EPA (end point adjustment)
And finally since both cars have different motors, you may have to adjust motor timing to get both cars to run the same top speed (if applicable or allowed if you are racing these cars).
IndyRC_Racer is offline
Old 03-26-2020, 09:50 AM
SteveM's Avatar
Trader Rating: 159 (100%+)
From a Google search, I found that the M-03 mini has an internal ratio of 3.134. I also found the following info on FDR:
Final drive ratio using 20T = 5.7979 (Rounding figure 5.80)
Final drive ratio using 19T = 6.1028 (Rounding figure 6.10)
Final drive ratio using 18T = 6.4419 (Rounding figure 6.44)
The M07 can take pinions from 17-24T with the following gear ratios suitable for stock racing:
  • 17T - 6.795:1
  • 18T - 6.418:1
  • 19T - 6.080:1
  • 20T - 5.776:1
  • 21T - 5.501:1
  • 22T - 5.251:1
  • 23T - 5.023:1
  • 24T - 4.813:1
SteveM is offline
Old 03-26-2020, 10:48 AM
I have a M03 and my solution is to use a 13.5T w/18T and I am happy. There was an aftermarket gear kit for M03 to make it faster but I forgot the brand. It could be 'Kose'
Dealer Xing is offline
Old 03-26-2020, 12:56 PM
SteveM's Avatar
Ride make the M-03 high speed gears.
SteveM is offline
Old 03-26-2020, 02:59 PM
Thank to all for the excellent advice
Tomoz is offline
Old 03-26-2020, 07:45 PM
gigaplex's Avatar
  • 17T - 6.795:1
  • 18T - 6.418:1
  • 19T - 6.080:1
  • 20T - 5.776:1
  • 21T - 5.501:1
  • 22T - 5.251:1
  • 23T - 5.023:1
  • 24T - 4.813:1
The M03 only supports 3 different pinions - 20T, 18T and 16T.
gigaplex is offline
Old 03-26-2020, 07:47 PM
gigaplex's Avatar
Yes. With a 20T pinion, M07 is 5.78 and M03 is 5.80 (rounded to 2dp)
gigaplex is offline
Old 03-27-2020, 04:24 AM
SteveM's Avatar
The numbers I posted were found online and I did not verify as I do not have an M-03 mini. I was just trying to help.....
SteveM is offline
