3RACING SAKURA ADVANCE S 6/4
#736
RaceVTA said they will have the kit w/alum chassis in stock within a week. Can't wait to order mine. Already have new motor, esc, servo, VTA body and tires
I would like to order some springs with it. What would be the hot setup for black carpet (not CRC, the stuff with a little less grip). Looks like the kit comes with 5.5 springs. I was thinking something a little stiffer, like 6.0T (hope I am deciphering there spring weight correctly).
#737
If you want to go stiffer, you need to have springs with less turns than the original ones.
More turns equals softer!
#738
SAK-A538 (racevta.com)
#739
#740
Thanks for the insights!
Yes, we will run at San Marcos and Santee, as both are nearish. Santee more so. We are in East County.
RCPassion puts on a great event.
Regarding extras, Im trying to walk the line of not buying everything right off the bat. I’m basically building two cars and I won’t my son to have some “buy in” if you know what I mean... I do want to have some of the things that make the car “better”.
Thank again!
Thank again!
#742
Thank again!
Thank again!
I am in El Cajon... about a 1 minute drive from Hobbytown .
#743
Thank again!
Thank again!
#750
I've been running exclusively in USGT. I just bring the spring set and ball stud washers with me and make minor changes if warranted with roll center. I'm at the point now where i definitely can see the car is a bit 'lazy', probably due to the chassis flex. But i really enjoy driving it regardless.
BTW, we run open motor for USGT also. Recommended gearing i was given when i started was a 4.25FDR which worked great for me at the San Marco's events. At the Santee location, the straight can be made much longer so i geared up a little more because the car sounded like it was topped out before halfway down the straight.
