3RACING SAKURA ADVANCE S 6/4
#631
Santa came early this year
Time to pimp out the old S64 with some new bling. Really liking the wire/plug less esc, makes it super easy to swab between cars while keeping the wiring short and clean.
#632
hey mopar, what is your parts list/upgrades you are running on your USGT car?
#633
#635
Finally found an afternoon off to finish assembling the s64. Box stock apart from ssk’s and steel outdrive spool.
No real issues. Someone here helped me regarding the 3mm ssk bearings and from reading this thread I was prepared for the fiddly spurgear assembly so took my time there. If anything the swaybar lockers ticked me off for a while, but operate freely now.
All in all without having known what to expect I’m amazed regarding fit&finish on this 90$ kit. And hey I could even fit my shorties without issues in this one.
Looking forward to giving it a go next trackday. And while I bought a proper touring body as well, this one was irresistible.
Alfa 2000
S64
Alfa 2000
S64
#636
Any idea when the next shipment of kits is going to be in?
#637
#638
Alfa 2000
S64
Alfa 2000
S64
#639
indeed. (item 48251)
And some tamiya wing posts (10115245). Body strengthened from the inside with thick extra lexan around mounting points. Held up fine for a roll yesterday (large asphalt track). Now just need to work on that massive understeer!
#640
New car
I have joined the list of S64 owners.
Although I have been and will be continuing to race my AE TC3, this is my first new in box touring car build since my Team Losi Street Weapon ~1998
Thanks RaceVTA.com you finally broke me down into getting one👍
#641
#642
Less rear toe will free it up, also softer front or harder rear spring and loose the front sway bar.
#644
RaceVTA ... ***NO SHIPPING 5/25-26, ALL ORDERS WILL SHIP 5/27, Monday cutoff 3pm ***
#645
Q to those that managed to stiffen up the chassis flex.
I'm at the point where I have ok steering, don't want more weight transfer back and forth and can power out of corners in a reasonably predictable way. However, "reasonably" is also my issue.
Would a stiffer chassis (less flex) give more predictability out of corners, or do the opposite and just remove grip overall. Trying to reach a setup that suits my hamfisted (aggressive) driving style and am rather ok with both current roll center and spring setup.
Mod, large asphalt track with good grip.
