Old 12-11-2002, 08:08 AM   #1
GoFaster's Avatar
Default LRP 7.1 question
Is there any way to get more punch out of a LRP 7.1 for stock racing?
Can you install capacitors like the Cyclone and GM?
GoFaster is offline   Reply With Quote
Old 12-11-2002, 03:37 PM   #2
GoFaster's Avatar
top
Old 12-11-2002, 03:58 PM   #3
You can install capacitors but capacitors dont add punch. Capacitors only make the volage more consistent. The LRP IPC SR is the same as the 7.1 but tuned for stock racing.
Cyclonus is offline   Reply With Quote
Old 12-17-2002, 02:19 AM   #4
Cole Trickle's Avatar
I dont think you can get more punch. But on my TX I adjusted the throttle to have some off-set, that is, the initial motor power are higher. That helped a lot.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 12-24-2002, 07:50 PM   #5
Neil Rabara's Avatar
Default Re: LRP 7.1 question
You can install the worlds kit by LRP, however the capacitors included in the kit are used to smooth out the power band and prevent glitching. The only way to get more punch is to get batteries with high voltage numbers.
Neil Rabara is offline   Reply With Quote
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 09:21 AM
Bolink TF drag car question and BL question parnelli97 Electric On-Road 2 08-20-2007 06:32 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 09:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 10:33 AM
