Old 03-17-2006, 06:22 AM   #1
fat500's Avatar
Trader Rating: 29 (100%+)
Default Shims under suspension mounts...what does it do?
what will putting shimms under my suspension arm mounts do. Front ,front and rear and rear, rear and front. EX. If i shim my rear front mount up 1mm the rear arms will be leaned back,what this do? Can someone give examples of f&r setups and the effect on handling? Thanks
fat500 is offline   Reply With Quote
Old 03-17-2006, 06:49 AM   #2
1fastdude's Avatar
Trader Rating: 15 (100%+)
XXX main makes an awesome booklet that describes most all adjustments.
★RCAmerica •Xray •Hudy •BSR •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is offline   Reply With Quote
Old 03-17-2006, 07:27 AM   #3
Stein Tumert's Avatar
Martin Crisp who wrote the book is active on this forum...
You can get the book from most good RC car shops in the US
(I think even Tower has it)
Stein
Stein Tumert is offline   Reply With Quote
Old 03-17-2006, 07:42 AM   #4
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
If you were to shim the front of the rear arm mount, it increases anti-squat. This helps to keep your vehicle a little more level when accellerating. If you shimmed the rear of the rear arm mount, it creates anti-dive. This helps to keep the vehicle level when braking. Shimming under the front of the front arm mount adds caster to the steering. Increased negative caster helps the car to track straighter and also adds negative camber when you turn the wheels giving you a little more turn in.
Tony
RcCzarOfOld is offline   Reply With Quote
Old 03-17-2006, 07:50 AM   #5
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
1fastdude is correct.....
The XXX Main book is great.....
I just wish I could get the PDF version, as I lost it and had to re-buy the book version.
Tres is offline   Reply With Quote
Old 03-17-2006, 08:16 AM   #6
XrayFK's Avatar
The new Xray setup book has everything you need and it's free and in PDF format. Just download it from teamxray.com
XrayFK is offline   Reply With Quote
Old 03-17-2006, 08:26 AM   #7
Send a message via AIM to R/C Anonymous
I'm no expert but when I made a few changes with my T2 and read the setup book afterwards it did the opposite of what was "supposed to happen" according to that book. I was also told by quite a few guys to not believe everything in that book.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 03-17-2006, 06:02 PM   #8
The_Stig's Avatar
I just try the adjustment and then drive the car. If I can tell the difference and I like it, it stays. If not, then it goes back to what it was before. Sometimes it does what it is "supposed" to do sometimes it doesn't.
The_Stig is offline   Reply With Quote
Old 03-17-2006, 07:37 PM   #9
protc3's Avatar
shimming your hinge pin blocks up or down changes roll center.it also allows you to add anti squat,pro squat,anti dive and pro dive.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-17-2006, 07:43 PM   #10
protc3's Avatar
i basicly run rubber tire asphalt and use these adjustments often.i always need to watch tire wear.it is difficult to get just right.it takes time.the lower the blocks the more traction i get,as i raise them it will start to break traction .the problem you run into is that you need to find the point where you have the traction you are looking for without eating or overheating the tires.once i find where i want to be i start adjusting weight transfer.there are so many adjustments on todays cars that you will find it difficult to fine tune every adjustment.stick with the coarse adjustments and then just fine tune.
Jason Breiner
BMI Racing
Team Associated
J Concepts
how many shims to use w/ 30% OS VRZ II straightaway Nitro On-Road 3 04-09-2007 12:28 PM
shims Renracer R/C Items: Wanted to Buy 0 04-08-2007 05:57 AM
Help! How many shims???? mtx3racer Onroad Nitro Engine Zone 2 07-16-2004 10:44 PM
motor shims..... SalvadoriRacing Electric On-Road 11 06-01-2004 06:58 PM
Rb C4 head shims rrgt_kid Onroad Nitro Engine Zone 1 03-06-2004 02:59 AM
