Like Tree227Likes
Schumacher F1
Old 03-10-2020, 05:11 PM
Dan
Dan's Avatar
Trader Rating: 74 (100%+)
Default Schumacher Icon F1
Thread for Schumacher's first ever F1
ASM, dawgmeat, qcrc and 6 others like this.
Dan is offline
Old 03-11-2020, 06:35 AM
Trader Rating: 14 (100%+)
Cool - Always wanted to try an F1 and keep it in the family
Double D Donuts is offline
Old 03-11-2020, 06:08 PM
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Nice, i hope this marks a more aggressive entry into the ETS series and support classes as well.
1/8 IC Fan is offline
Old 03-11-2020, 06:14 PM
qcrc's Avatar
I hope that this is going to be released. I've always thought that pod design would be fantastic for F1. I was real close to having a chassis made but I couldn't decide which front end I was going to use. I put it on the back burner as I moved away from F1. This will definitely bring me back.
qcrc is offline
Old 03-11-2020, 07:08 PM
Should make for a simple rear wing mount.
Scott_T is offline
Old 03-11-2020, 07:29 PM
under the current rules the front supension has to be the Tamiya 2 different versions.
BullFrog is offline
Old 03-11-2020, 07:35 PM
Trader Rating: 21 (100%+)
What makes the car different?
photeckk is offline
Old 03-11-2020, 08:46 PM
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Like the TRF102? don't know never saw any pic
OVA is offline
Old 03-12-2020, 01:42 AM
the two frontends : basically CRC is like the orginal Tamiya frontend and the rest like xray is the other. look at the ROAR rules.Both have been modified alittle but the basic design.
BullFrog is offline
Old 03-15-2020, 04:24 PM
Airwave's Avatar
CRC design is a little bit different from Tamiya, as you can have adaptative camber and reactive caster, it is quite important.
Airwave is offline
Old 03-15-2020, 08:42 PM
Really- it is the same basic Tamiya orginal frontend on the CRC. The orginal CRC F1 had the Tamiya frontend. All version present is just a modified version of the F103 frontend.I still have some of the orginal F1 chassis by CRC when we raced on foam tires.Most everyone use the newer Tamiya frontend .
BullFrog is offline
Old 03-16-2020, 06:26 AM
purplerain's Avatar
there’s no reactive caster on the CRC front end.
purplerain is offline
Old 03-16-2020, 08:31 AM
robk's Avatar
Trader Rating: 22 (100%+)
If you shim the rear screw between the lower and upper bulkhead, you can get some reactive caster in there.
robk is offline
Old 03-16-2020, 08:33 AM
Funny thing is, there could easily be by just molding alternate top caps (1543) for the front end.
purplerain likes this.
ptrhahn is offline
Old 03-16-2020, 10:26 AM
you mean the part I believe 3racing made years ago . Got part if it just sitting around (base).
BullFrog is offline
