Like Tree266Likes
Schumacher F1
Old 02-29-2024, 09:10 AM
  #391
Originally Posted by F1fletch
This car is on my list to purchase soon. Glad to hear you are doing well on carpet. Mine would be run on carpet as well. What tires are you running?
im using exotek double reds on the rear and single reds on the front. Make sure to glue the front sidewall all the way from the wheel to the top contact area of the tire
Kruss45 is offline
Old 03-11-2024, 07:16 PM
  #392
Another outstanding day of racing with my icon2. This car continues to impress me and everyone who sees it on the track. The biggest compliment I get is people talking about how flat it looks in the corners.
Kruss45 is offline
Old 04-01-2024, 08:52 AM
  #393
Didnít get to race my icon2 this past weekend but I was able to get some good testing done. I wanted to see what changing the roll center would do, so I raised the roll center to 1.75mm shims and the car definitely rotated around the rear end a lot more compared with having 1mm shims in. I settled on 1.5mm shims for the roll center. Next I wanted to know how adding shims to the bump steer would affect the car. I went from 1mm to 2mm and initial turn in improved a lot. These changes allowed me to run faster lap times up front instead of waiting for the tires to heat up. I hope this info helps anyone else who has an icon2 F1.
Kruss45 is offline
Old 04-11-2024, 12:39 AM
  #394
Schs2013's Avatar
So i will be getting a Icon 2.
Only have experience with a previous Speed Passion SP-1 F1 how does the Icon2 compare to the SP-1?
Schs2013 is offline
Old 04-11-2024, 06:12 PM
  #395
Regional Moderator
disaster999's Avatar
The Icon would be a completely different concept compared to the SP-1. Performance wise it would be very different
disaster999 is offline
Old 04-11-2024, 07:37 PM
  #396
Schs2013's Avatar
nothing like relearning to drive a new f1 then.
thanks for the help.
Schs2013 is offline
Old 04-17-2024, 10:47 AM
  #397
V12
V12's Avatar
Which oil to use for the gear diff?
The manual says 1K for the beginning but I think it will depend on traction level, tires, track etc.
I will run 21.5T at large, open outdoor track with foam tires. Low to medium traction.
V12 is offline
Old 04-21-2024, 10:23 AM
  #398
Ice_nl's Avatar
4k should be a good starting point.
Ice_nl is offline
Old 04-24-2024, 10:44 PM
  #399
porsche928gs's Avatar
For low traction, I'll go for the 1k when running rubber tires, maybe 3k with foam.
porsche928gs is offline
Old 04-28-2024, 08:27 PM
  #400
Can anyone explain to me what I'm missing first time out today with the worlds edition on high grip asphalt car was pushing like crazy my rear gear diff is notchy I took it apart a few times when j built it but I couldn't find the issue can anyone tell me what to look for? Should i.just put the ball diff in and be done?
knightrider is offline
Old 04-28-2024, 10:47 PM
  #401
Hello,
is someone running a Montech Hypercar body on their Schumacher Icon 2? If yes how did you mount the body struts? Some Pictures of the modification would be really helpful.
Thanks in advance.
Slyd3x is offline
Old 04-29-2024, 01:49 AM
  #402
Regional Moderator
Originally Posted by Slyd3x
Hello,
Thanks in advance.
You need a front bumper, something like this
RCM Le Mans F1 1/10 Bumper Set for F104 Style Front (w/o posts) RCM-F1LM-01
or this
https://www.fenixracingshop.com/conv...e-chassis.html
If you have a printer you could try this
https://cults3d.com/en/3d-model/game...-10-bumper-set
Old 04-29-2024, 01:51 AM
  #403
Regional Moderator
What are your settings for the car currently?
As for the diff, it needs some time to break in. Also if you over tighten the cover you might deform the case putting uneven pressure onto the gears making it feel like it grabs are a certain point on the rotation.
Old 04-29-2024, 12:55 PM
  #404
I built it to kit specs I got a setup from a guy on fb thatís slightly different and I plan to copy it. The car started out great but as the day went on, the steering just went farther and farther away. It looks like all my diff fluid leaked out. Iím going to
put a ball diff in it until I get the gear diff figured out
Old 04-29-2024, 06:14 PM
  #405
Regional Moderator
I built it to kit specs I got a setup from a guy on fb that’s slightly different and I plan to copy it. The car started out great but as the day went on, the steering just went farther and farther away. It looks like all my diff fluid leaked out. I’m going to
From experience with F1 cars, softer front springs would increase turning. pushing weight to the front of the car would also help. Increasing caster would make the car easier to drive
Also what tires are you running with the car?
