Like Tree227Likes
Schumacher F1
Old 12-22-2022, 07:31 AM
  #301
Rick Vessell's Avatar
Originally Posted by BadSign View Post
short wheelbase
Front ackerman holes - Rear holes
Black soft front springs
Tires glued wheel to mold line
190mm wide
2° camber
10K sides
15K center
Soft black side springs
Nickel rear spring - Red kit spring
2.5mm drop - 1.5mm droop
0 anti squat.
alloy pivot mount with .5mm shims on both sides
ball diff
Reduce caster slightly
Lightest rear wing you have
Notes added in bold.
BadSign likes this.
Rick Vessell is offline
Old 01-23-2023, 11:04 AM
  #302
I am having an issue with the left front spacing being different thant the right front and you cannot get the tweak out. Broke a steering block and replaced the steering block with same shims as prior. Cant find anything bent. Loosed all the deck screws to "re-center" but still nothing. I would have to run the right side spring adjuster down about 5 full turns to even be close to equal weight on the front wheels. The entire front end is off now and I plan to re-build with new springs etc. but does anyone have any other ideas?
dyoung is offline
Old 01-23-2023, 11:07 AM
  #303
Dan
Dan's Avatar
Trader Rating: 74 (100%+)
Have you checked the front posts and the center rear upper deck post if they are bent? I found these problematic areas if you have the original V1 posts.
Dan is offline
Old 01-23-2023, 11:35 AM
  #304
Originally Posted by whoopass View Post
I quite like the Icon 2, but for the life of me I cannot understand WHY they mounted the steering post on the the top deck! Surely the chassis would've been more sensible? Due to the change in caster, changes toe...
I always forget to reset my steering when I make castor changes because of this lol
ChadoSan is offline
Old 01-23-2023, 11:46 AM
  #305
I have not but will now, thx!
dyoung is offline
Old 01-23-2023, 12:38 PM
  #306
bmwjoon's Avatar
The posts to the top deck bend. Also check the ball joints in the top deck that the kingpins slide into.
bmwjoon is offline
Old 01-23-2023, 01:06 PM
  #307
Will do, thank you!
dyoung is offline
Old 01-30-2023, 11:13 AM
  #308
For the Icon2, did anyone else have issue with the aluminum wing mount in the back where the supplied screws (5mm) weren't long enough? They wouldn't tighten down, so went digging through the old parts bin and found some 6mm ones that seemed to work.
I've been out of F1 for a LONG time, but when I saw this thing pop up on ebay for $250 I couldn't pass it up. I've also been looking for a decent body to run, which ones fit the best? I'll be running on a smallish black carpet track.
scott.langford likes this.
Vwmofo is offline
Old 02-01-2023, 11:20 AM
  #309
Trader Rating: 18 (100%+)
Anyone else have difficulty installing & removing the rear CRC pre-mounts on the new wheel hexes that come with the gear diff? I had to sand to remove the paint off the hexes to make easier.
Red141 is offline
Old 02-01-2023, 12:51 PM
  #310
Dan
Dan's Avatar
Yep, the CRC wheels are normally tight fitting on your typical F1 hub but the Schumacher gear diff hub tolerance is on the high side so that makes for a super tight fit when combined.
Red141 likes this.
Dan is offline
Old 02-16-2023, 01:06 PM
  #311
bmwjoon's Avatar
Tolerance is super tight. I didn't sand anything but I had to cycle the wheel on and off at least 10 times? After that it's quite easy to pull on and off.
Taz_S likes this.
bmwjoon is offline
Old 03-06-2023, 10:22 PM
  #312
Default Best Icon Body
What is the best body with space in rear to cover side damper and clear center mount plate for center damper?
I had a PF 1545-30, I moved to back .25” to try and get more clearance but I don’t like it.
chuck in indy is offline
Old 03-07-2023, 10:51 AM
  #313
Dan
Dan's Avatar
Looks like fat500 has given some good feedback on bodies in the other chat. I can at least confirm the Montech F18 works good on the Schumacher.
On my other Icon, I have the same PF body you have. I just cut it entirely just ahead of the side tube dampers. Doesn't look nice but it was the only way I could have it without major binding.
Dan is offline
Old 03-07-2023, 11:26 AM
  #314
bmwjoon's Avatar
I use F18. It is an easy fit. I mean it’s what they use on the box.
Also I hear the gonzo racing both fits and works well. Other than eBay I think Monaco RC sells it.
bmwjoon is offline
Old 03-07-2023, 01:30 PM
  #315
I had the same issue, a longer screw will fix it. Not sure if it was stripped from the factory or if the threads weren’t deep enough.
scott.langford is online now
