Like Tree243Likes
Schumacher F1
Old 11-18-2022, 09:42 PM
  #286
Dane's Avatar
Trader Rating: 26 (100%+)
how is parts availability for this car in the US?
Dane is offline
Old 11-18-2022, 09:51 PM
  #287
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Discount RC is in Michigan and ships fast (free ship over $50). The car is pretty durable. All I've broken is one plastic knuckle and bent a few of the front suspension posts before Schumacher came out with the revised stronger posts.
Juniorabca likes this.
Dan is offline
Old 11-22-2022, 08:31 AM
  #288
Trader Rating: 6 (88%+)
Originally Posted by Obsidian
Looking for a solution to accurately measure caster on the Icon2. Was looking at Exotek's caster Doodles but not sure if they will work on the Icon 2... has anyone tried them?
I try them
you need F1ultra front hub to do that !
Quinny45 is offline
Old 12-19-2022, 01:22 PM
  #289
I have the same question. I have seen a couple of people post a measurement but not sure where the measurement is to or from. In general, are Icon users on black carpet using max or min caster, or in the middle?
dyoung is offline
Old 12-19-2022, 01:31 PM
  #290
Dan
Dan's Avatar
I'm using more caster on black carpet. ~9 degree range usually.
Dan is offline
Old 12-20-2022, 02:19 AM
  #291
whoopass's Avatar
I quite like the Icon 2, but for the life of me I cannot understand WHY they mounted the steering post on the the top deck! Surely the chassis would've been more sensible? Due to the change in caster, changes toe...
Red141 likes this.
whoopass is offline
Old 12-20-2022, 03:12 PM
  #292
BadSign's Avatar
Trader Rating: 15 (100%+)
I have to use almost no caster to avoid traction roll. I'm at 1-2°
BadSign is offline
Old 12-20-2022, 07:02 PM
  #293
The Teacher's Avatar
Trader Rating: 61 (100%+)
BadSign, do you glue your front tires?
The Teacher is offline
Old 12-21-2022, 07:27 AM
  #294
Rick Vessell's Avatar
Like Teacher asked, glue on front tires?
What is your rear droop and anti squat? Damper tubes? Side springs? Rear springs?
Rick Vessell is offline
Old 12-21-2022, 10:22 AM
  #295
BadSign's Avatar
short wheelbase
Front ackerman holes
Black soft front springs
Tires glued wheel to mold line
190mm wide
2° camber
10K sides
15K center
Soft black side springs
Nickel rear spring
2.5mm drop
0 anti squat.
alloy pivot mount with .5mm shims on both sides
ball diff
BadSign is offline
Old 12-21-2022, 11:14 AM
  #296
bmwjoon's Avatar
short wheelbase
190mm wide
2° camber
10K sides
15K center
Nickel rear spring
2.5mm drop
0 anti squat.
ball diff
Cool setup. My car has way more rear damping than that. I'm 80 in the center and 40 on the sides. I usee 8 degrees caster and the thing is a beast. I tried very low caster and the understeer was terrible. My car wouldn't transfer any weight on to the front tire but my damping is significantly higher.
bmwjoon is offline
Old 12-21-2022, 03:14 PM
  #297
BadSign, have you checked the post that attach the top deck to the bottom? If you have the lightweight post that originally came on the car it's possible they are bent.
Rick Vessell likes this.
Old 12-21-2022, 03:42 PM
  #298
BadSign's Avatar
I have the Icon 2, so it should be the heavier posts, I believe?
BadSign is offline
Old 12-21-2022, 09:12 PM
  #299
BadSign's Avatar
They are not bent, still round.
BadSign is offline
Old 12-22-2022, 05:53 AM
  #300
bmwjoon's Avatar
On my Icon I use a 4000mah slim battery with a 50g weight and I glue the front tires to about 2mm below the mold line, really has no hint of flipping on black carpet.
If you have a fat battery and low damping in the rear you have a lot of weight transferring on the back which usually makes cars flip. It's hard on the Icon to get weight up front but I have about 40 grams total in front of the halfway point of the wheelbase.
Try that and add some caster back in.
BadSign likes this.
bmwjoon is offline
