Like Tree275Likes
Schumacher F1
Old 03-16-2020, 01:11 PM
  #16
MarkBurgess's Avatar
Great to see Andy running and winning with the Schumacher Prototype F1.
I'm pretty sure an earlier version has been raced previously
MarkBurgess is offline
Old 03-22-2020, 04:31 PM
  #17
Airwave's Avatar
Originally Posted by BullFrog
Really- it is the same basic Tamiya orginal frontend on the CRC. The orginal CRC F1 had the Tamiya frontend. All version present is just a modified version of the F103 frontend.I still have some of the orginal F1 chassis by CRC when we raced on foam tires.Most everyone use the newer Tamiya frontend .
Original F103 Front, nothing's moving but the kingpins
CRC WTF1, articulated:
By the way you are right for the reactive caster, I forgot I printed parts for that. But still, you can setup the camber and the caster, which is not the case on F103
And this is the 3Racing hop up:
Airwave is offline
Old 03-23-2020, 03:42 AM
  #18
If you want reactive castor check out the Carisma CRF1
bencos is offline
Old 03-23-2020, 10:41 AM
  #19
The second picture of the second frontend did come out later for the 103 frontend. Still my statement about what frontends are legal stand Tamiya type either one. If anyone has the center part of the 3racing parts shown in the 2nd frontend I would like to get it.
BullFrog is offline
Old 11-05-2020, 08:13 AM
  #20
Dan
Dan's Avatar
Trader Rating: 76 (100%+)
https://www.racing-cars.com/news/new...f1-coming-soon
Dan is offline
Old 11-05-2020, 08:55 AM
  #21
R/C Tech Elite Member
JayL's Avatar
Roar doesn't have Rubber tire F1 rules.....
"8.7.6.2 Tire type: Foam only"
I think you mean Rob's USVTA F1 rules, that's what everyone uses
JayL is offline
Old 11-18-2020, 06:27 AM
  #22
https://www.racing-cars.com/new-prod...vember-2020%2f
krish667 is offline
Old 11-18-2020, 07:58 AM
  #23
Pretty sexy stuff from Schumacher!
DavidNERODease is offline
Old 11-18-2020, 03:15 PM
  #24
Dan
Dan's Avatar
Discount RC Store should have them in on Monday. It is $350 and I've pre-ordered a kit from them. They are an awesome dealer to buy from, I've bought stuff for my Schumacher buggies in the past.
Dan is offline
Old 11-20-2020, 02:09 AM
  #25
Andy Murray's Avatar
Hey guys,
With the launch of the Schumacher Icon I thought it would be a good idea to share some information to help you guys out.
Firstly, I have linked my current setups for high grip carpet, and medium grip tarmac/asphalt. I will work on a lower grip setup sheet for indoor and bumpy outdoors soon. You can find them on the Technical information page on Schumachers website or below.
I have added into the notes section on these 2 setup sheets all the part numbers for the Speed Secrets I use and some other parts that it might be nice to buy with the kit.
High Grip Carpet
(Please remove spaces after h and w) h ttps://w ww.racing-cars.com/content/files/Technical-Info/Set-Up-Sheets/ICON_AM_High_Grip_Carpet_MB.pdf
Medium Grip Asphalt
h ttps:/.w ww.racing-cars.com/content/files/Technical-Info/Set-Up-Sheets/ICON_AM_Arena33_Smooth_Asphalt.pdf
I hope you guys enjoy the car and I'll try to check back regularly if you have any questions about the car or need any setup support. I'll do my best to help!
Juniorabca likes this.
Andy Murray is offline
Old 11-20-2020, 02:51 AM
  #26
Default Rear axle
Is the rear axle geometry different than the Eclipse? Are they interchangeable?
coda1820 is offline
Old 11-20-2020, 07:08 AM
  #27
The Icon diff fits the Eclipse 1,2 and 3.
However, the Eclipse diffs require a small modification. Using a needle file just .2mm needs taking off the diameter thats in the way of the button heads holding the hex wheel clamp on.
Its very easy to do if you want to use old diffs from the lmp car/spares though.
Alternatively you can just replace this one part if you dont fancy the modification. (to use Eclipse diffs in the ICON) (you can see where the flat would need to be, on the right of the second photo.
(remove the space after 'h' and 'w') h ttps://w ww.racing-cars.com/f1/icon/alloy-washer-carrier-rh-icon-u8120?returnurl=%2fsearch%3fq%3du8120
Andy.
coda1820 likes this.
Old 11-20-2020, 07:28 AM
  #28
sugs's Avatar
Fixed it for you Mr Murray.
Carpet setup
Asphalt setup
Alloy washer carrier
dawgmeat and Andy Murray like this.
sugs is offline
Old 11-20-2020, 10:23 AM
  #29
patorz31's Avatar
Mine will be Tuesday. Looks so good I ordered 2.
patorz31 is offline
Old 11-20-2020, 10:43 AM
  #30
Dan
Dan's Avatar
Andy, good to see you here and congrats on the 1/12 worlds win earlier this year. Got a question, what is the full length of the lower chassis in millimeters?
Dan is offline
