Like Tree225Likes
Schumacher F1
Old 08-08-2022, 02:26 PM
  #256
bshookup, gwhiz, ALBOP and 1 others like this.
ChadoSan is offline
Old 08-12-2022, 07:10 AM
  #257
clinttredway's Avatar
Is the gear diff a necessity for black carpet?
clinttredway is offline
Old 08-12-2022, 08:25 AM
  #258
Rick Vessell's Avatar
Not an absolute necessity. I have run both ball diff and gear diff. For ball diff you will want a very heavy grease to slow the diff action and prolong time between rebuilds. I use Tamiya VG grease and it seems to work well. Some like to use the Tamiya AW grease but being wax based I have found it gets 'looser' as it heats up.
dawgmeat likes this.
Rick Vessell is offline
Old 08-12-2022, 08:28 AM
  #259
Awesome. I will give that a try. Thank you.
Old 08-12-2022, 01:55 PM
  #260
fat500's Avatar
Trader Rating: 45 (100%+)
Raman, gwhiz, LonnyJ1950 and 2 others like this.
fat500 is offline
Old 08-12-2022, 01:56 PM
  #261
fat500's Avatar
so far I'm seriously impressed with this car
gwhiz, ALBOP and ChadoSan like this.
fat500 is offline
Old 08-13-2022, 09:43 AM
  #262
gwhiz, LonnyJ1950 and ALBOP like this.
ChadoSan is offline
Old 08-19-2022, 11:14 AM
  #263
fat500's Avatar
So I've heard some racers complain that when adjusting the top deck camber plate that their camber can be slightly off. This is due to tolerances in the slot and the screws. I have solved this issue by using zero tweak screws that come with my Roche EVO 3 there is a noticeable difference using these screws and a standard M3. I would recommend everybody switch to these. They can be found on Roche USA's website and I believe coming like a pack of 12.
They're called ulp screws they're ultra low profile and they're slightly wider at the top so anywhere you put them on the car they fill the hole of the carbon fiber so you get no tweak .
fat500 is offline
Old 08-19-2022, 11:18 AM
  #264
fat500's Avatar
Here's a close up photo of the screw compared to a standard M3 it's hard to tell the difference but it's there I had a slight amount of play with the standard screws as soon as I put these in all the play went away.
I use them on all the front arm holes with incredible success they basically eliminate all tweak or all possibility of tweak due to manufacturing tolerances and make the front end incredibly accurate. I really enjoying the ease of setup on this car and happy to report that the icon 2 gear diff works flawlessly with zero leaks with the kit 1000 weight oil in it.
fat500 is offline
Old 08-21-2022, 08:38 PM
  #265
Originally Posted by waitwhat View Post
You are supposed to use that nut to set the angle of the pod. Rear ride height is adjusted using the eccentric axle bearing holders. Basically there are several pairs of the part the rear axle bearings press into. Each pair has the bearing in a different place, which changes the ride height.
Hi, Just building my new Icon 2 and have found the flange bearing 1/4x3/8x1/8 (Yellow) are a very loose fit in the ride height adjusters. The amount varies from adjuster to adjuster and I am concerned that the bearing will rotate in the adjuster and not on the axel. Has anyone experienced this and is there a fix available?
Neville51 is offline
Old 08-22-2022, 01:57 PM
  #266
fat500's Avatar
That is normal for this car I'm so used to them being tight on other cars. It's actually a good thing cuz it helps to keep the bearing from binding or overheating. My bearing can fall out of them but there's no play.
Juniorabca and Neville51 like this.
fat500 is offline
Old 08-24-2022, 11:27 PM
  #267
Cool...Thank you very much
Old 08-25-2022, 03:22 AM
  #268
The Teacher's Avatar
Trader Rating: 61 (100%+)
ChaodSan, what body is that in your pic?
The Teacher is offline
Old 08-25-2022, 10:57 AM
  #269
Its an older protoform one F1-Fifteen or Fourteen I think. It does not fit in any way I wouldn't get one. Its been cut so much and spread out just to look like it fits but it doesnt.
ChadoSan is offline
Old 09-01-2022, 12:49 PM
  #270
Back at it this weekend
ChadoSan is offline
