Like Tree224Likes
Schumacher F1
Old 06-15-2022, 06:10 PM
  #241
Originally Posted by Dan View Post
Maybe krazed builds could introduce unslotted upper arms or have a bushing insert system for caster for a truly bulletproof front end.
Its been looked at but dont know the level of interest in the material and inserts.
My experience is the Icon has such a wide range of caster available.
It would be a big chunk of inventory doing all 3 different camber tops and probably just 3 caster inserts. (4-6-12*)
Originally Posted by dawgmeat View Post
Another area of concern with regard to tweak is the lower arms. Once they take a good hit they’ll have a a certain bend to em’ and will cause the the indifference in camber
Only if Kraze Builds make a-arms and a upper deck then I’ll give it another try
I know they are drawn Im just not sure if theyll do them yet.
I havent seen much talk about it being a problem.
Theyve done Xray ones due to their flex but the Icons felt much stiffer then those on my car.
Robbob is offline
Old 06-29-2022, 08:09 PM
  #242
supasmo's Avatar
Default Rear Ride Height
How do I set the rear ride height of the Icon F1? I tightened this nut down a bit but I don’t think that’s right. Some threads talk about spacers, which I can find them for the front but does it equally effect the rear as well? Lost on setup here but love driving this!!
supasmo is offline
Old 06-29-2022, 08:58 PM
  #243
You are supposed to use that nut to set the angle of the pod. Rear ride height is adjusted using the eccentric axle bearing holders. Basically there are several pairs of the part the rear axle bearings press into. Each pair has the bearing in a different place, which changes the ride height.
bshookup likes this.
waitwhat is offline
Old 06-30-2022, 09:05 AM
  #244
supasmo's Avatar
Dang I overlooked that! Thank you for pointing me in the direction.
supasmo is offline
Old 07-14-2022, 09:44 PM
  #245
Does anyone know if the WRC F04 or F05 body fits the Icon at all? Looking for a new body for next year as I am so not happy with the one that I have on it currently. Or is there any good recommendations for black CRC high grip carpet?
Jon
Juniorabca is offline
Old 07-15-2022, 08:30 AM
  #246
shadowracer24's Avatar
I ran mine with the montech f18 body and the car was dailed everytime I ran it.
dawgmeat and Juniorabca like this.
shadowracer24 is offline
Old 07-23-2022, 12:05 AM
  #247
What are the recommended option parts for the icon 2?
RcAlesi is offline
Old 07-31-2022, 10:31 AM
  #248
fat500's Avatar
Trader Rating: 45 (100%+)
Anyone running icon 2
dawgmeat likes this.
fat500 is offline
Old 08-04-2022, 09:00 PM
  #249
How do you mount the montech 22 front wing on these cars?
ChadoSan is offline
Old 08-05-2022, 06:05 AM
  #250
Ice_nl's Avatar
It mounts the same as the older Montech wing with 2 screws. The holes are on the same place but the plastic is less thick so if you use the U8174 Wing thread insert kit you need to add some spacers. I used 2mm spacers on mine:
Robbob likes this.
Ice_nl is offline
Old 08-05-2022, 07:41 AM
  #251
What’s a good starting final for these? Running an R1
ChadoSan is offline
Old 08-05-2022, 09:43 AM
  #252
Dan
Dan's Avatar
Trader Rating: 74 (100%+)
25.5 motor? How big of a track?
Dan is offline
Old 08-05-2022, 02:14 PM
  #253
yes 25.5 fairly big carpet track beachline
ChadoSan is offline
Old 08-05-2022, 05:57 PM
  #254
With the R1 start with a 88 spur and 27 to 30 pinion. Thats what I run on mine there depending on track bite and motor temp. Usually starts out a little loose early in the day then the bite comes up by main time.
Old 08-06-2022, 11:13 AM
  #255
fat500's Avatar
Really enjoying building the icon 2.....very nice quality.....my first schuie
dawgmeat and bshookup like this.
fat500 is offline
