Schumacher F1
#226
Do you happen to know what part numbers these were? Or a good place to order said parts from? Where I am here in Michigan, Shumacher is barely, if at all, supported. I wanna change that!
#227
Shipping would be murder for you I think.
EDIT: Here's the link for the Schumacher ICON spares page on the Schumacher website. You'll be able to get all the info you need here I think. Schumacher website
#228
https://www.discountrcstore.com/schu...amper-set.html
I recommend if you are in the states, to order from Phil at discount RC store. He is even in Michigan too!
#229
#230
Question just for curiosity ..... Inline vs Across battery?
Ive seen some in the past have inline but productions are always across.
Pros and Cons? (besides real estate for electronics mounting)
Just looking for feedback on what it would do in a F1.
Ive seen it in 12scale benefit the non-modified classes but never dug into what it would do in F1.
#231
#232
#234
My camber is off with the stock strap. 2 degrees left and 3.5 for the right side. New car just built and has not been on the ground yet.
#236
Honestly once you upgrade to the heavy duty posts, it does not tweak as much. Still the fastest F1 of the ones I have tested (on black carpet anyways).
For the new build issue, I would contact Schumacher for them to take a look at it. Could be a manufacturing issue.
Maybe krazed builds could introduce unslotted upper arms or have a bushing insert system for caster for a truly bulletproof front end.
