Like Tree224Likes
Schumacher F1
Old 01-03-2022, 01:21 PM
  #181
shadowracer24's Avatar
The part number for the heavy duty posts is u8161. You can get them at discount rc store. There really isn't a heavy duty upper deck but different straps for the front that change the camber and width of the front end. Other than a few different spring sets for setup I really haven't needed to get anything else.
shadowracer24 is offline
Old 01-03-2022, 02:34 PM
  #182
Awesome. Thanks so much for the quick reply. My mistake on the upper deck. It showed up on Discount RC Store when I searched 'heavy duty,' but it was for another vehicle. I appreciate the help!
mnb128 is offline
Old 01-04-2022, 12:35 PM
  #183
Anytime bud. Always happy to help. I love how this car drives on carpet and like helping others get the same fun with it. It can be a little frustrating to get set right but once you get there this thing is a beast.
Old 01-08-2022, 04:27 AM
  #184
Dan the Man's Avatar
Trader Rating: 41 (100%+)
Can anyone recommend bodies that will fit the ICON? A few of the guys that run them said that there are some bodies where the pods rub on the servo horn.
A body that actually looks cool would be a bonus
Dan the Man is offline
Old 01-08-2022, 01:57 PM
  #185
Ice_nl's Avatar
My Schumacher Icon with Bittydesign Type 6r and Montech f18.
Bittydesign Type 6r.
Montech f18.
Both bodies fit well and there is enough clearance near the servo, I do use an alloy servo arm, so that might give me more space than a servo saver. I usually run the Montech because that is a newer type and should give better handling as it is narrower and lighter. I think the only way the servo arm could hit the body is if it is mounted to far back. The servo arm doesn't need to turn much to get full steering.
Ice_nl is offline
Old 01-08-2022, 02:34 PM
  #186
Dan
Dan's Avatar
Trader Rating: 74 (100%+)
I'm running a Montech F22 body on mines. Originally was going to use an F18 but found the F22 was a bit better for room.
Dan is offline
Old 01-08-2022, 07:48 PM
  #187
Has anyone tried the F104 2017 body? That’s what I was going to go with. Despite all the newer options out there, it’s still my favorite looking body.
mnb128 is offline
Old 01-09-2022, 02:46 AM
  #188
ErikJan's Avatar
You are very brave putting a Mercedes model on a Dutch track these days .
Dan the Man, fat500 and Robert K like this.
ErikJan is offline
Old 01-09-2022, 09:40 AM
  #189
Thanks for the answers. While I'm asking questions, any good option parts for running on asphalt? I've got the tuning springs set and silver side springs; anything else?
Old 01-09-2022, 10:59 AM
  #190
The dampener set if you haven't gotten it yet. It diffinately helps on rough asphalt.
Old 01-09-2022, 11:01 AM
  #191
It's to narrow in the body to fit these newer cars. You would probably end up hacking it all to hell to get it to fit.
Old 01-09-2022, 01:17 PM
  #192
The mass damper?
Mass damper
Old 01-09-2022, 05:24 PM
  #193
That’s good to know. Thank you for the heads up.
mnb128 is offline
Old 01-09-2022, 05:42 PM
  #194
Originally Posted by Dan the Man View Post
The mass damper?
Mass damper
Yep that's it.
Old 02-02-2022, 11:12 PM
  #195
Trader Rating: 341 (100%+)
Hi gang. Long tome techie but new to Icon. No nothing about this type of tuning(12th scale) . I hv read tge manual multiple times and looked at some set ups. My car came on alum chassis. We have high bite black carpet. Going to carbon chassis. How do you adjust front droop? Just not understanding how to adjust this or front ride height. Tx in advance gang
konasubs is offline
