Like Tree264Likes
Schumacher F1
Old 07-26-2021, 02:11 PM
  #151
Trader Rating: 6 (88%+)
Originally Posted by Red141
I run a lot of caster and yes, the kingpins do bind with the plastic pivot balls. What Roche parts did you use?
Roche - 6mm Pivot Ball Set, Front Suspension (310077)
Roche - Pivot Ball Bushing (340092)
Roche - 7x5x1 O-ring (340091)
the 2 balls with the flat head goes face down in the lower arms the face is flat to have a better contact with the front spring
when you put the pivot ball insert in the arms be sure they fit not too tight because the balls will bind !! if its too tight take a 400 grid sand paper roll it and turn it in the hole to sand it equaly watch many time to do not overseize it ! need to fit with a normal push ** don't scratch the balls they are coated **
if the fit is good and the pivot ball move not like you take a pliers with pivot ball remover pin and play with it remove and install it 2 3 times and check
https://www.hudy.net/xhudy/showimage...58efac46f64b0f
and you need the Roche O-ring schumi O-ring is too big
Red141 likes this.
Quinny45 is offline
Old 07-27-2021, 09:55 PM
  #152
Default Help
Looking for black carpet set up CCR med grip 25.5
hotrod306 is offline
Old 07-28-2021, 01:17 PM
  #153
https://www.racing-cars.com/technical-information-icon
take Andy murray High grip carpet setup ( shimizu 571 572 like CRC tire )
Quinny45 is offline
Old 08-08-2021, 04:51 PM
  #154
shadowracer24's Avatar
Put the Icon on the pole and a main win
in race 2 of race for the birds at beechline today. This thing keeps getting quicker Everytime I run it. Stayed consistent all day long. The winner of this series gets an entry for the F1 class at the snowbirds this year so hopefully I can keep this pace up. Was the fastest car in the class every time it hit the track.
shadowracer24 is offline
Old 08-10-2021, 09:30 AM
  #155
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Just picked up a 2nd Icon as a backup car. Also noticed Discount RC Store now carries the stronger and beefed up aluminum posts.
Dan is offline
Old 08-10-2021, 11:16 AM
  #156
dawgmeat's Avatar
I need help with front end tweak.
Left side camber reads 2 degrees while the right side read from 2.5 to 3 degrees
I have the extra strong front posts and it reads the same with both U8076 and U 8123
dawgmeat is offline
Old 08-10-2021, 03:10 PM
  #157
Did you replace the rear post as well? If you didn't it may be bent and that's throwing the front off. Had the same issue with mine till I replaced the rear post as well. Found the original had a slight bend in it.
Old 08-10-2021, 03:21 PM
  #158
dawgmeat's Avatar
Are you referring to U7864?
dawgmeat is offline
  #159
Spoiler
Hope you enjoy. Was a fun race my car started on the pole. Don't know how to get the video put on here but that's the YouTube address for it.
Old 08-10-2021, 03:27 PM
  #160
Yep that's the one. It's also a little tricky getting the front set at times. The trick is to snug the screws up just enough to hold things in position but can still easily slide the top plate front to back till you get both sides where to want, then snug up the front screws first then the back.
Old 08-10-2021, 05:39 PM
  #161
dawgmeat's Avatar
I replaced all stand post and I'm still have the mismatch camber.
dawgmeat is offline
Old 08-11-2021, 06:33 AM
  #162
Trader Rating: 18 (100%+)
My camber is mismatched too using the 1.5 top plate but not as drastic as yours that it affects the car's handling. This is with the new posts all around.
dawgmeat likes this.
Red141 is offline
Old 08-11-2021, 07:33 AM
  #163
Dan
Dan's Avatar
Check if your lower arm or top plate is bent too. And correct shimming.
Honestly not a huge fan of the Schumacher front end and the posts/slots. It is very easy to get a tweaked front end.
Dan is offline
Old 08-11-2021, 08:42 AM
  #164
Check for bent front axles or kingpins and that the steering hub is not deformed. Check that there is no excessive play in the kingpin pivot balls. Ensure your steering links are the same length and that your steering rack is centered. Lastly, ensure you have the same thickness shims between the camber strap and the posts closest to the kingpins on both sides of the car.
waitwhat is offline
Old 08-11-2021, 03:22 PM
  #165
dawgmeat's Avatar
Thanks for all the replies U7938 was the problem
dawgmeat is offline
