Drilling holes in pistons >
Like Tree2Likes
  • 1 Post By daleburr
  • 1 Post By Racermac73
Old 02-26-2020, 11:03 PM
b3master's Avatar
Default Drilling holes in pistons
Whats the best way, or tips ,for drilling clean holes in delrin shock pistons.
The last set gave me hard time to completely remove the burrs created by the bit. Even by hand still not satisfied with them.
b3master is offline
Old 02-27-2020, 12:53 AM
It is often better to drill a smaller hole first and then the final diameter ( preferably with a reamer). Using new drills helps. Lubrication can help (special products, or WD 40, any oil etc.)
Obey, that deburring can change the hole intrance geometry. Very good funnel like entrance can increase oil flow by 15% up to 25%.
Erhard is offline
Old 02-27-2020, 01:47 AM
daleburr's Avatar
You'll need a drill press to do it accurately
Buckaroo likes this.
daleburr is offline
Old 02-27-2020, 10:17 PM
Of course! I had assumed this is clear.
Erhard is offline
Old 02-28-2020, 05:29 AM
You do not need a drill press with new bits and a steady hand and very simple to perform the biggest task is getting rid of the burs when completed
Stevie S is offline
Old 02-28-2020, 06:31 AM
Braxamus's Avatar
https://pilotrcproducts.com/collecti...-w-alum-handle
Braxamus is offline
Old 02-28-2020, 06:55 AM
Rick Vessell's Avatar
Pick up some circuit board drills. They come in every diameter we would need for pistons and cut very clean. Amazon and Ebay list them from various places.
Rick Vessell is offline
Old 02-28-2020, 07:01 AM
Racermac73's Avatar
Go to the Midwest Circuit Technology website, they specialize in mini drill bits and cutter bits. Drill bits are available in .05MM intervals and have a 1/8 shank, so they fit in a Dremel tool perfectly. I've ordered from them for several years now and their service is top notch and it always ships quickly.
Rick Vessell likes this.
Racermac73 is offline
Old 02-28-2020, 07:07 AM
Dan the Man's Avatar
Trader Rating: 41 (100%+)
But why?
Dan the Man is offline
Old 02-28-2020, 12:27 PM
TurnNBurn's Avatar
FWIW, I recently bought the Pilot R/C set linked above. A really nice set with an aluminum handle that has a rotating base so that you can spin it comfortably in your hand (your hands may vary). You get a 1mm bit, then 1.2 to 2.0mm bits in .1mm increments.
TurnNBurn is offline
