Best Battery for 17.5 TC >
Like Tree3Likes
  • 1 Post By dawgmeat
  • 1 Post By tbrymer
  • 1 Post By tbrymer
Old 02-18-2020, 01:25 AM
wstuart's Avatar
Trader Rating: 114 (98%+)
Default Best Battery for 17.5 TC
Iím getting back into TC racing. I see there are now HV 8000+ lipos. Are these necessary for the 17.5 class. What is a good trade off between weight and capacity? 7000? 6000?
also, how are the protek lipos? I really like the one I have in my 2wd buggy.
wstuart is offline
Old 02-18-2020, 09:04 AM
dawgmeat's Avatar
IP from Intellect America
Brian10811 likes this.
dawgmeat is offline
Old 02-18-2020, 09:07 AM
tbrymer's Avatar
R1 6000mah
Buckaroo likes this.
tbrymer is offline
Old 02-18-2020, 10:00 AM
Trader Rating: 14 (100%+)
R1 5800mah ULCG or EAM 5800mah ULCG
glennhl is offline
Old 02-18-2020, 04:44 PM
Buckaroo's Avatar
Originally Posted by tbrymer View Post
R1 6000mah
Just bought and ran one of these batteries.......HOLY &%$$......IR amazingly low, charges fast, does not drop off AT ALL for an 8 minute run, does not get hot......just an amazing battery.
Buckaroo is offline
Old 02-18-2020, 06:26 PM
any numbers for the IR?
i have 5800 from another vender...getting 1.5 each cell on a high amp charge
racer 111 is offline
Old 02-18-2020, 06:28 PM
Buckaroo's Avatar
Never got more than 2 each cell high or low amp charge, usually less than 3 total IR. I have several others that are 5600 and 5800 from other vendors, and the performance of the R1 6000 on the track doesn't drop off at all by the 8 minute mark whereas the others do at the 6ish minute mark in a 17.5 TC. In my USGT and VTA cars, there's no difference in performance due to the lower draw. YMMV
Buckaroo is offline
Old 02-18-2020, 07:17 PM
tbrymer's Avatar
I have a 5800 R1 that is .7 LOL
tbrymer is offline
Old 02-19-2020, 08:21 AM
Is that on a normal charge/discharge cycle or 40/40? By normal I mean 10/10 or even 20/20.
malkiy is offline
Old 02-19-2020, 08:36 AM
tbrymer's Avatar
Definitely not a normal charge. LOL
tbrymer is offline
Old 02-19-2020, 09:22 AM
Typically you would use 7000+ batteries on large tracks (140+ ft) where you're on throttle the majority of the time. Most of these are outdoor tracks. For indoor, mainly carpet racing, you would run smaller capacity packs.
malkiy is offline
Old 02-19-2020, 01:27 PM
gigaplex's Avatar
Nobody runs packs that large where I am on our larger tracks. They're usually in the 5000 to 6500 range.
gigaplex is offline
Old 02-19-2020, 02:49 PM
cneyedog's Avatar
I tried Sunpadow, I had a 6600mah Black Phantom pack for TC and a 6000mah Gold pack for my Vta Car. Charged @ 20 amps on both, discharged and charged again. 1.0 IR per cell on my Icharger for the 6000 pack and 1.1/1.2 on the 6600 pack. I was happy with them
cneyedog is offline
Old 02-21-2020, 01:16 PM
Brian10811's Avatar
That is a impressive IR. I for sure need to buy a new battery. As bad as I hate to say, the Trinity white carbon batteries are the best numbers I have came across in a long time.
Brian10811 is offline
Old 02-21-2020, 01:36 PM
dizzy1's Avatar
Trader Rating: 26 (100%+)
Depends on track and car. Light car that needs weight and on large track, 8000+, keeps voltage higher longer in the cycle. Heavy car stick with 6000ish to keep balance in check. Tight tracks, i'd recommend any of the 5000-6000 LCG batteries. Personally i run IP 8400s in 17.5-21.5 classes on large track.
dizzy1 is offline
