CK 25 Gearing
Old 02-10-2020, 07:19 AM
Default CK 25 Gearing
Hey guys i am new to the 1/12 scale world. So new as in i am building my first car.... i am going to be running 17.5 on med grip black carpet. Track dimensions are 80ft by 40ft. So not a super big track by any means. Trying to figure out where i want to be on gearing. Again running a 17.5 motor. I am going to buy every other 3 up and 3 down so i am looking for the starting point. So it you say 43/72 then i am going to buy 37, 39, 41, 43, 45, 47 49. So that way i have range from track to track.. I just dont know where to begin at. The kit comes with 72, 80, 88, 96 spurs.
Thank you for any help.
jman4210 is offline
Old 02-10-2020, 07:34 AM
This sort of advice is best given by someone that has actually run at your track....have you asked anyone there?
sps3172 is offline
Old 02-10-2020, 08:50 AM
For 12th scale you need to calculate your rollout due to the tires changing in diameter as they wear. Here is tool to help you out. https://www.tqrcracing.com/rc_tools/rollout.asp
As far as the rollout you need that is dependant on what motor you are running. I use a Trinity xfactor with a 82mm rollout at 36* of timing.
BEMO2019 is offline
Old 02-10-2020, 11:00 AM
Trader Rating: 57 (100%+)
50/72 Should get you started. That said, your tire size plays into gearing in 12th scale. So get a roll-out calculator, plug your rear tire size in, and then get gearing based on what the motor builder recommends. Good luck.
Race19s is offline
Old 02-11-2020, 09:35 AM
Trader Rating: 21 (100%+)
72/50 as mentioned is a good start but it depends on motor and track size AND layout.
different motors like different gearing.
phatboislim is offline
