Old 03-14-2006, 05:33 PM   #1
squeege's Avatar
Default leads on gxf getting hot & melting
when i am discharging a pack at 30 amps with my turbo 35 gfx the large positive alligater clip gets really hot , it starts smoking and melting the red boot around clip. any advise?
squeege is offline   Reply With Quote
Old 03-14-2006, 05:42 PM   #2
send it back
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 03-14-2006, 05:45 PM   #3
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 03-14-2006, 07:38 PM   #4
Send a message via AIM to rcguy2477
You can try installing a new alligator clip, or see if there is something that would cause an extreme amount of resistance.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 03-14-2006, 08:08 PM   #5
tbeardmore's Avatar
I agree --- send it in for repair
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 03-14-2006, 08:15 PM   #6
GKC
GKC's Avatar
Send a message via ICQ to GKC
I had the similar problem of the clips getting way to hot melting the rubber boots and it was due to a bad solder joint between the lead and the alligator clip. No problems doing 30A after resoldering the joint with some silver solder.
Hope that helps.
GKC is offline   Reply With Quote
Old 03-14-2006, 10:51 PM   #7
MClinton's Avatar
CE has some of the best customer support in the business. You're best off just sending it in and I'm sure you'll get prompt and helpful responses to your concern.
-Matt
MClinton is offline   Reply With Quote
Old 03-16-2006, 08:44 PM   #8
squeege's Avatar
resoldering the alligater clips did the trick . Thanks to everyone for thier advise.
TB-02 Ball Diff Melting Tamiya_Driver Electric On-Road 8 07-31-2009 06:40 AM
Melting glow plug coils! performula Onroad Nitro Engine Zone 27 05-18-2007 05:51 AM
Futaba Plug melting, ESC Qs Vortex Buggy Electric On-Road 2 09-09-2003 12:48 AM
Melting Plugs! LosiFromHell986 Electric Off-Road 3 03-27-2003 11:16 PM
Spur Gear Melting jreed Electric Off-Road 1 01-13-2003 06:25 AM
