Awesomatix A12 Pancar >
Like Tree1571Likes
Old 01-17-2020, 07:07 AM
  #16
Airwave's Avatar
Originally Posted by Oleg Babich
Can easily be converted to a quadcopter :-)
Airwave is offline
Old 01-17-2020, 08:07 AM
  #17
jetnjme's Avatar
Trader Rating: 19 (100%+)
a wonderful design, i cant wait to have one (or 3) in my hands... excellent job!
jetnjme is offline
Old 01-17-2020, 08:08 AM
  #18
Originally Posted by JoeyE
Like he says!
Brian10811 likes this.
rhodopsine is offline
Old 01-17-2020, 09:17 AM
  #19
sugs's Avatar
LMAO!!!
sugs is offline
Old 01-17-2020, 05:59 PM
  #20
Pablo Diablo's Avatar
Almost answers all the questions I had! Is there anything at the rear of the chassis/battery holder to locate the rear pod from wandering left/right?
Pablo Diablo is offline
Old 01-17-2020, 06:04 PM
  #21
Trader Rating: 38 (92%+)
When are they shipping to
usa
Rcforlife13 is offline
Old 01-18-2020, 04:29 AM
  #22
Very interesting - one downside I see is locking the front wheels with screw instead of self-locking nut. This seem like rush for differentiation instead of rational engineering.
Yorick is offline
Old 01-18-2020, 05:24 AM
  #23
The steering hub is one-piece 7075 T6 part. No space for the thin steel axle due to all inner space of the hub is using for damping. So the wheel axle is also alu alloy. M3 outer thread on alloy axle looks too fragile for me. Normal M3 screw needs less space and weights less compare to the possible M4 nut.
Try to draw this and you will see the reasons.
smenes likes this.
Oleg Babich is offline
Old 01-18-2020, 06:49 AM
  #24
Zerodefect's Avatar
I like that. Looks nicer using a plain old screw.
On my CRC front axles, I have to run shims inside and outside the wheel to take up play. It's annoying. Every time I swap tires, I lose a shim that costs more than a bearing. I plan on using a 4-40 die to thread those axles down further, like an xray axle, so I only have shims on the inside.
Zerodefect is offline
Old 01-18-2020, 07:36 AM
  #25
RacinJ, Al Sodano, Flygio and 4 others like this.
Old 01-18-2020, 08:12 AM
  #26
Zerodefect's Avatar
Is there a shock piston in there?
Old 01-18-2020, 09:33 AM
  #27
Yes.
Old 01-18-2020, 09:49 AM
  #28
Zerodefect's Avatar
That's cool. No more gooey hairballs stuck to my car.
LonnyJ1950 likes this.
Old 01-18-2020, 11:48 AM
  #29
Got the point, if it is not steel, it might be too fragile for M3 thread, question is if the alloy axle will not bend? Is it standard thread on both sides and standard M3 screws? If so it might be bit more prone to loosening M3 screw on left axle, where the friction on might move inner part of bearing.
Yorick is offline
Old 01-18-2020, 11:50 AM
  #30
Yes, hate that as well on Corally SSX12, that seems very similar to older CRC in many areas.
impson likes this.
Yorick is offline
