Droop & setup question >
Like Tree10Likes
  • 1 Post By Zerodefect
  • 3 Post By tbrymer
  • 4 Post By glennhl
  • 2 Post By tbrymer
Old 01-12-2020, 06:44 AM
Default Droop & setup question
I like setting my droop with blocks. But was told to do it with the shocks off,so I seen in some videos they do it with the shocks on. I think they measure where the arm rest. So if one side is different from the other side. Wouldn't that be a shock problem (you would rebuild your shock length to match ) cuzz if you adjust the spring tension that would change tweak?
when setting droop over ride height, would you use setup wheels or use the wheels you race with?
TeamThibault is offline
Old 01-12-2020, 06:58 AM
SteveM's Avatar
Trader Rating: 156 (100%+)
I measure droop with the shocks removed and ensure that I have the same value left to right. When I build my shocks, I also measure to ensure they extend equally.
SteveM is online now
Old 01-12-2020, 07:00 AM
Super Moderator
Marcos.J's Avatar
Trader Rating: 208 (100%+)
i o it with the shocks off , but before i do that i make sure that the chassis is flat. i loosen the top deck screws and place it on a set up board( or a glass table) make sure is flat. tighten the top deck then do the droop. also make sure the shocks are all equal lengths
here is some good info
https://www.youtube.com/watch?v=m_Sc...w#action=share
Marcos.J is offline
Old 01-12-2020, 10:16 AM
Zerodefect's Avatar
TC droop is same as off road. Set car on blocks, measure at the axle.
I balance the car with the shocks off. Everything else, shocks on.
Don't underestimate how much the arms and whatnot can warp.
Lonestar likes this.
Zerodefect is offline
Old 01-12-2020, 11:08 AM
tbrymer's Avatar
I measure downstop with shocks on.
sosidge, Jack Kloeber and glennhl like this.
tbrymer is offline
Old 01-12-2020, 11:57 AM
Trader Rating: 14 (100%+)
I also measure droop with shocks on. It's how the car actually runs and you can uncover an issue if the shocks are not extending far enough.
glennhl is online now
Old 01-12-2020, 01:26 PM
Super Moderator
Marcos.J's Avatar
If you do it with the shocks off when you mount the shocks back on it will be obvious if you have a shorter shock
Marcos.J is offline
Old 01-12-2020, 03:56 PM
tbrymer's Avatar
If you do it with shocks on, it will be obvious because you will not be able to get a small downstop value before your shocks limit it. It is also good because it's like a double check that your shocks are all the same length if you do ever reach the limit.
tbrymer is offline
