ARC R12 Touring Car
#106
I built my R12 last night and took it out for its Maiden voyage today. The build went so smoothly that it was almost boring. Lol. Just make sure to sand down the big diff gears 0.12mm for smooth diff action.
On my local tiny crc ft2 track, the R12 on its Maiden voyage was almost on par with my Awesomatix mmx.
R12 ran a fast lap of 6.39s and top 15 of 6.51s. Mmx FL was 6.38 and top 15 of 6.46. Not a bad result for its first run. I'll tinker with the setup a bit and run a couple of more packs through it on Wednesday.
#109
On asphalt, with the kit top decks, I've found the car is quite better with the front one cut. And removing four of the top deck screws using just the inner ones. Have the option ones installed now and will test soon. I have an AMX MMX in my stable and top deck tuning is beneficial with that chassis. The R12 is very similar in chassis flex.
Marcos, i'm curious to read your findings abut this chassis so keep us posted.
#111
Super Moderator
#113
#115
Car was money today for me the first time out. Kit setup with a spring change, rear toe, and droop changes. All my testing was in USGT. This car is so easy to drive it felt great running with confidence with a car I knew could finish a race. Will be back out next weekend with a couple of changes. Rear diff fluid will be increased for hot weather racing.
#116
I ran mine for the first time this past weekend and definitely need to make some changes. Running on Medium grip Asphalt, the kit setup felt very numb and stable. I did not have springs to play with but will next week. I also think some softer ANTI-roll bars are need. It looks like currently only 1.3s are available for the car? The bars from the R11 will not work because the gap in the bend points is too narrow for this car.
#117
Super Moderator
#118
#120
Why the centered belt rear differential instead of a centered front spool?You could have the servo more centered...
