Help with Orion Advantage touch duo >
Old 12-29-2019, 07:17 PM
Default Help with Orion Advantage touch duo
Hi to all.I was missing around with setting changed contrast and I went to Low and now screen is black and I cant see and setting so I could bring contrast back up.I unplugged the charger for about 2min hoping that would reset it.but no good.any help would be great thanks
Mackman40 is offline
Old 12-30-2019, 04:36 PM
Airwave's Avatar
You should try to perform a factory reset... blindly!
Take a look of the paragraph 14: https://www.manualslib.com/manual/85...ch.html?page=4
Clicking the + should be easy, then try to click in the bottom right corner to reach "More" and finally click in the middle right to finally reach the Factory Reset...
Let's hope it will solve your problem.
Airwave is offline
