Simple green
Old 12-25-2019, 10:51 AM
Default Simple green
Do you guys use simple green as pre tire prep then use traction compound ? Do you leave it on over night? Is there any tire prep you leave on over night? Do you use it as traction compound?
TeamThibault is offline
Old 12-25-2019, 01:35 PM
Zerodefect's Avatar
No. It cleans rubber fine, but it dries it out.
I use SXT to clean and treat, than a quick squirt of Tag body spray to keep it on.
Zerodefect is offline
Old 12-25-2019, 01:39 PM
And why would you do that? What will u do if your super prepeperd tyres set die on second run off the race day? I keep tyres preparation as simple as possibile so i can do it between runs.
Khargulec is offline
Old 12-25-2019, 02:59 PM
fyrstormer's Avatar
Almost all tire compounds are just various forms of degreasers, much like Simple Green. They get the rubber really clean so it can stick properly for a few laps. The only tire compound I've heard recently of that actually soaks into the rubber and softens it permanently is made by TDK.
fyrstormer is offline
Old 12-25-2019, 04:07 PM
Put TDK on a sticker - say your setup board - and you’ll start to understand how it manages to soften the rubber.
it might be “non toxic” but it is still quite nasty stuff.
cplus is offline
Old 12-25-2019, 07:24 PM
Trader Rating: 14 (100%+)
What’s the name of the sauce?
photeckk is offline
Old 02-07-2020, 11:08 AM
TDK works great. They have a new compound out. Only compound that is allowed and it works really great. Tires come off very clean.
quertreiber is offline
