Old 03-12-2006, 04:29 PM   #1
anthony390's Avatar
Send a message via AIM to anthony390
Default NOVAK TC2 PROBLEM....HELP
i have the novak tc2...and well it gives power to the reciever and the servo is able to turn but it doesnt give power to the motor...the green solid light turns on when fully on throttle but no responce on the motor....blinking green light on when the breaking is fully pressed so the light are fine but not the power to the motor
the motor is perfecly fine because it works on a different novak esc but not on the novak tc2
HELP???PLEASE
anthony390 is offline   Reply With Quote
Old 03-12-2006, 05:07 PM   #2
bukil's Avatar
Trader Rating: 39 (100%+)
Post
Assuming, you are talking about the Novak brushless system. What kind of novak ESC and novak motor?
bukil is offline   Reply With Quote
Old 03-12-2006, 06:08 PM   #3
anthony390's Avatar
actually im running a regular brused motor...
Old 03-12-2006, 06:36 PM   #4
bukil's Avatar
You have to be more specific on your ESC. I know its novak but what kind?
Old 03-12-2006, 06:43 PM   #5
Team Speedy's Avatar
Trader Rating: 42 (100%+)
First things first, I'm almost positive that Novak never made a "tc3". Did you mean the Tc2?
Second try this, reset the control. Make sure all wires are plugged in the right direction and are in the correct spots. Make sure you follow the insturctions on how to reset it. I believe that if you hold the reset button, hold it in, give it throttle, release it, it should flash green or turn a solid green. Then after that push up for brake and it should either flash. Release it and it goes to solid red. I believe that is how it is suppost to reset. But for sure, check your connectors going into your receiver. Leave the servo one alone and double check the throttle one. It's receiving the commend, but something isn't going well with the speed control. I would recommend consulting the manuel and double checking that first. If I think of something else, I will defintly post it here for you. Good luck with that.
RcAmerica | Xray | Hudy |
Team Speedy is offline   Reply With Quote
Old 03-12-2006, 08:02 PM   #6
Trader Rating: 35 (100%+)
Send a message via AIM to Sean R
Sounds like maybe a hung brush. Take the shunt and let the brush snap on the comm. A good cleaning probably couldn't hurt either.
Sean R is offline   Reply With Quote
Old 03-12-2006, 10:27 PM   #7
anthony390's Avatar
WHOOOPS...yea it is a tc2...sorry about that
ok so ill double check the connections and reset the esc 2marrow
Old 03-12-2006, 10:27 PM   #8
anthony390's Avatar
like i said...its not the motor....but thanks anyway
Old 03-12-2006, 10:38 PM   #9
BeetleBailey's Avatar
My Cyclone did the same thing. I tried everything then contacted Novak. They told me to buy a new speed control, they no longer work on them.
BeetleBailey is offline   Reply With Quote
Novak GTB, Fan problem daveaustin5 Radio and Electronics 8 03-03-2008 10:28 PM
Novak GT7 problem daztrac Electric Off-Road 9 01-06-2008 11:03 AM
Novak XBR Problem jnor R/C Tech Site Forum 4 12-31-2007 07:57 PM
Odd Novak GTX problem exint2 Electric On-Road 8 11-23-2006 09:20 AM
Novak TC2 Problem was ist los? Electric On-Road 1 09-28-2002 09:01 PM
