XRay X12 2019 vs 2020 >
Old 12-04-2019, 09:25 AM
Default XRay X12 2019 vs 2020
I hope this is the right place to post this. I see I can get a 2019 version of the X12 for $225 which is $100 off. Are the changes to the 2020 version make it worthwhile to spend the extra $100?
dfitzsim is offline
Old 12-04-2019, 10:46 AM
Trader Rating: 30 (100%+)
Unless you want to run a micro servo, and even then it is probably better to pick up the new servo mounts. I have the 2020, but I only got it because I sold my 18 at the end of last season. There were a few nice updates from the 18, but the cars drive pretty much the same. I would say the 19 would be just fine.
trilerian is offline
Old 12-04-2019, 11:29 AM
Thank you very much for the reply.
dfitzsim is offline
Old 12-04-2019, 09:23 PM
JeffofSpace's Avatar
I do like the sidelink hangers on the 20. Prevents some rubbing. The new shock mount position rearward seems good too. Those were beneficial in stock for me. My mod car is an 18 and I am happy with it as well. You can always upgrade later piece by piece if you want.
JeffofSpace is offline
Old 12-05-2019, 04:39 AM
Car Breaker's Avatar
Get 2019, bigger area for electronics and much cheaper. Use the 100usd difference for tires
Car Breaker is offline
Old 12-05-2019, 06:47 AM
Thank you everyone for your replies.
dfitzsim is offline
Old 12-05-2019, 07:19 AM
Trader Rating: 37 (100%+)
I still run a stock 18 with a spool in 17.5 and have no problem keeping pace.
chensleyrc1 is offline
Old 12-05-2019, 11:46 AM
Thanks everyone. I bought the 2019 US version for $225. I was thinking of running this ESC/Motor combo:
HWA38020241 - Hobbywing XR10 Justock Sensored Brushless ESC/SD G2.1 Motor Combo (17.5T)
dfitzsim is offline
Old 12-05-2019, 11:48 AM
Dan
Dan's Avatar
Trader Rating: 63 (100%+)
You need a 1S esc but there are ways to make that Justock ESC run on 1S... Otherwise look at the XR10 Stock spec 1S
That motor is not competitive either but if you're just starting out, it should be fine.
Dan is offline
Old 12-05-2019, 12:52 PM
Wow thanks Dan. I didn't notice that it's 2 to 3s. Thank you
I don't need to be competitive as I'm just starting out. I can work on that later.
So maybe this motor and ESC then:
https://www.amainhobbies.com/hobbywi...408011/p784979
https://www.amainhobbies.com/hobbywi...112751/p579727
dfitzsim is offline
Old 12-05-2019, 01:14 PM
Dan
Dan's Avatar
That ESC is good. The motor, for the same money, you can get the SMC lowrider motor on clearance. It will be a better motor than that Hobbywing.
https://www.smc-racing.net/index.php...product_id=520
Dan is offline
Old 12-05-2019, 01:29 PM
Zerodefect's Avatar
Might consider the next model up Esc from HW. I just blew one of those up, and it was never ''quite right'' for most of it's life. And it's bottom case half was plastic, not aluminum. If I wanted a plastic case, I would have bought a Tekin.
My SMC version of the pro Esc's are working great. I think that the SMC was the same esc as this:
I think I'm going to try a Tekin again, for 1s. At least I'll have someone to send it to, when it nukes. SMC has no 1s Esc's on their website anymore.
Zerodefect is offline
Old 12-05-2019, 02:59 PM
CL
CL's Avatar
Trader Rating: 34 (100%+)
I have used the XR10 Justock with a 17.5/13.5T motor without a booster, and it works without issues.
CL is offline
Old 12-05-2019, 04:47 PM
I run only asphalt in hot PHX az. I was considering the new gear diff. Any issues you see with that on asphalt?
Azsmartbet is offline
Old 12-05-2019, 05:29 PM
Wow thanks everyone. Iíll look into those motor and esc recommendations.
anyone ever use orca escís? They look very similar to some of those hobbywing units.
dfitzsim is offline
