FTR racing
Old 11-21-2019, 04:47 PM
Default FTR racing
We are extremely glad to announce that we are bringing a samurai sword to the North American 1/12 scale market.
topfuelhobbies is offline
Old 11-21-2019, 04:56 PM
Features
Consistency is always a key factor in any racing scene as we know. And “reliability” and “durability” is a base to push your car to its limit. The Parsec-12A offers incredible drivability with must have featured items such as solid rear axle with locked diff, 7075 2.5mm aluminum main chassis, etc. Feel the drivability of the Parsec-12A and push it to the limit that you have ever gone.
  • Compact low-CG servo mount offers improved chassis flex balance.
  • Includes two types of front upper arms with friction damper or without.
  • Increased suspension setting range with widened front suspension blocks.
  • Locked rear diff hub is equipped as standard. Super lightweight carbon rear axle shaft is also compatible with ball differential application.
  • 7075 grade low CG, llightweight, aluminum motor mount.
  • Titanium turnbuckles.
  • Newly designed POM machined side link tube.
  • Super durable ball seat.
  • Precision Center shock: Shock upper rod-end can be chose from standard cap or adjustable cap (screw type aluminum cap) to adjust the rod end length.
  • Newly designed lightweight wheel hub. Thickness has been reduced while it maintains its durability. M2.6 wheel mounting screw hole.
-Specifications
Length:261mm
Width:F168mm,R170mm
Wheelbase:198mm
-Item requid
  • 2ch propo with electric speed controller & 1servo radio controll set
  • Battery Charger
  • 3.4V or 7.4V Short Lipo Battery
  • 540size brushless motor
  • Body
  • Tire/Wheel
  • 64pitch pinion gear
  • Ball diff grease
  • Silicon Oil
  • Instant Glue
* This kit is for Small servo only.​
Front upper arms
1/9
Old 11-21-2019, 09:50 PM
DirkW's Avatar
Originally Posted by topfuelhobbies View Post
-Item required
  • Battery Charger
  • Body
  • Tire/Wheel
  • Ball diff grease
  • Silicon Oil
  • Instant Glue
1S is 3.7V, not 3.4V.
DirkW is offline
Old 11-22-2019, 08:01 AM
Thank you
