Schumacher Eclipse 3 1/12th pan car kit >
Like Tree181Likes
Old 03-25-2020, 01:32 PM
  #91
Hugh Jazz's Avatar
Originally Posted by Azsmartbet View Post
Anyone that has this kit. Is there anyway someone could measure the distance of the screws that mount the lower arm to the chassis? I’m trying to see if I can use my x-ray front shims on this
Won’t work. First thing I tried. I think it’s closer to the crc ride height shims
Hugh Jazz is offline
Old 03-27-2020, 06:13 AM
  #92
Flygio's Avatar
The screws are too close to fit the x ray shim. You've got 2 options: either you dremel the pockets in the shim or you simply cut the shim in the middle into 2 parts. You can now put it beneath the king pin , instead of shimming the whole front carbon assembly. Far better in my opinion.
Flygio is offline
Old 04-16-2020, 06:13 PM
  #93
F1fletch's Avatar
Well I got a fair deal and ordered an E3 today, really looking forward to build. Do I have to use a mini servo with this kit? For some reason I thought I was able to use a Std size ..lol
F1fletch is offline
Old 04-17-2020, 01:09 PM
  #94
No hope, standard size servo doesn't fit.
Dominic Au is offline
Old 04-17-2020, 02:16 PM
  #95
F1fletch's Avatar
Yeah, I figured I had this one confused with another. I think I found an Xpert Servo that will work, mini style
  • Dimensions: 33.6x15x29.5mm
F1fletch is offline
Old 04-17-2020, 06:40 PM
  #96
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
Looking back the podium in IFMAR Worlds... why James Allison was there??? He should be busy on the preparation of W11.
Sorry, a bit off topics.
F1fletch and Flygio like this.
Mike Schumacher is offline
Old 04-18-2020, 02:23 AM
  #97
TrevCoult's Avatar
What, you mean this James Allison? One of the people helping organise the 12th Worlds works for the Mercedes F1 team and arranged for him to pop down and hand out the trophies, he doesn't live far away.
F1fletch likes this.
TrevCoult is offline
Old 04-19-2020, 05:56 AM
  #98
Probably he showed up there and introduced "DAS" technology to 1/12 RC world!
Old 04-19-2020, 02:14 PM
  #99
Trader Rating: 37 (100%+)
Anyone else have an issue with the chassis holes for the center dampening post not being countersunk?
****Update****
Schumacher is sending a replacment. Thanks!
chensleyrc1 is offline
Old 04-19-2020, 05:04 PM
  #100
F1fletch's Avatar
Anyone tried adapting a gear diff to the E3?
F1fletch is offline
Old 04-19-2020, 11:51 PM
  #101
TrevCoult's Avatar
Some people used to run the XRAY one in the E2 so that would also work in the E3, but to be honest nowadays most run a spool.
choisan and F1fletch like this.
Old 06-20-2020, 02:21 AM
  #102
3DFLYER's Avatar
I have myself a couple eclipse 3s on the way cant wait to give them a run ♥️
qcrc and TrevCoult like this.
3DFLYER is offline
Old 06-21-2020, 02:30 AM
  #103
TrevCoult's Avatar
If you have any build questions just post on here, but to be honest they go together pretty well.
Juniorabca and 3DFLYER like this.
Old 06-24-2020, 06:47 PM
  #104
Hi
just wondering how high a 1/12 pan car body should be?
my eclipse 3 chassis front height in 3.5mm and 3.7mm rear,
is it ok to have a 1/12 scale body for about 3.8~4mm high? from a plate ground?
because every-time I finished a run I can see my body is touching the ground
shaokw75 is offline
Old 06-25-2020, 01:01 PM
  #105
F1fletch's Avatar
Great question, I too want to know what ride height to set it at. We have a bumpy smaller asphalt track (medium traction) and I need a baseline setup
@TrevCoult
F1fletch is offline
